Looking for harmonic balancer or 3.9/4.0 lower end - Defender Source
Old February 9th, 2014, 04:30 PM
airbornrover's Avatar
airbornrover
William Skidmore
SIII 109 SW
Let me know what you guys have.
Long story short, truck was running rough. Changed out a few things, including the fuel fliter and the 90 was still running rough but smoother.
Pops ends up taking it to the mechanic and he finds that the gasket is blown between 2 and 3 cylinder then finds that the crank pulley is wobbling and 22 degrees out. Turns out the bolt was loose and also caused the key (shorthand) egged its slot a little.
So we are going for the harmonic balancer since its only at a 100,000 miles. If that doesnt work then we'll just find a low mileage engine and switch it out.
Old February 9th, 2014, 06:08 PM
Iamkraig's Avatar
Iamkraig
Kraig
1987 defender 110
Frank has a complete 4.0 for sale
http://www.defendersource.com/forum/...eferrerid=9704
You can use the fasanal shipping program.
Just a thought.
Old February 9th, 2014, 06:16 PM
robertf
Robert F
1995 Discovery
I've got a 4.0 balancer I don't need. FYI They don't have timing marks like a 3.9
Old February 9th, 2014, 07:46 PM
airbornrover
William Skidmore
SIII 109 SW
Far as I know, thats ok. cause I can unbolt the pulleys from the old harmonic balancer and bolt them onto the new harmonic balancer. If I am off on this someone let me know.
Old February 9th, 2014, 08:30 PM
robertf
Robert F
1995 Discovery
Can't do that. 4.0 is 1 piece unlike the 3.9 stuff
Old February 23rd, 2014, 01:07 AM
airbornrover
William Skidmore
SIII 109 SW
Thrown a loop with this mess for finding a pulley. Mechanic found one from a 3.9 defender but when he put it on the crank it didnt fit. And when he went to look at the engine number it had been removed. Need to know if there are any other marks or items to look for to decipher the origins of this engine.
Its a replacement engine that I bought back in '04 from a shop in Canada.
Any help in this would be appreciated.
Old February 23rd, 2014, 09:58 AM
James Pierce's Avatar
James Pierce
James Pierce Jr.
Is it a cross bolted block?
What size is the lower radiator hose? Hans Defender Technical Discussions 2 February 11th, 2006 06:29 PM
Roll Cage End Caps oldscratchggf For Sale - Parts 12 October 27th, 2005 07:16 PM
Hella Light Bar Plastic end Cap 48vphantom Wanted 0 December 19th, 2004 12:53 AM
blown front end & sucky wheel locks jabber Defender Technical Discussions 6 October 25th, 2004 07:35 PM
Half Roll Cage End Caps boshea Wanted 4 July 14th, 2004 04:05 AM
