Looking for a Rover Torque Flight with Adapters - Defender Source
Old October 15th, 2012, 07:40 AM
RockShow's Avatar
RockShow
Ben Goodwin
1996 D1
I am looking for a one of the old Torqueflight 727 transmissions from the mid-80's RRC and the Bell housing and transfer case adapters. I mainly need the adapters and the info on the output shaft so that I could find the proper tranny but it would be easier for every one involved to just take the whole thing. Or any one that has the specs and could machine a set of the adapters would work too.
Ben
Old October 15th, 2012, 08:36 AM
Now that's different. Guess you have a gray market Rangie?
Old October 16th, 2012, 08:54 AM
Are you trying to put an atlas transfer box in?
Old October 16th, 2012, 07:48 PM
RockShow's Avatar
RockShow
Ben Goodwin
1996 D1
Nope, I got a couple of old Buick 300's and a 340 that I am going to rebuild as a project and I have been told that the Buick will bolt to the 727.
Old October 17th, 2012, 12:02 PM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
I was unaware that a mopar trans had a BOP bellhousing
Old October 17th, 2012, 02:09 PM
crown14's Avatar
crown14
Verticalscrote
Jeff what I meant was, the Buick 215/Rover V8 bellhousing bolt pattern and the Buick 300/340 are different from each other... Meaning a 727 from behind a RV8 won't bolt to a 300/340 (to my knowledge).
Old October 17th, 2012, 08:44 PM
RockShow's Avatar
RockShow
Ben Goodwin
1996 D1
It has been a while since I did alot of research on the subject. Sort of got burned out on it when I tore down the first 300 block and found 2 blown out sleeves and one cracked. As I recall, I think you could use the International Version of the 727 but there was something that may have needed to be swapped out.
As for the bell housing, I am not 100% sure if the bolt pattern is the same or not but worst case I figured if I have the adapter I can either mill out new holes, fab a new one, or I think D&D Fab has one.
It may not ever work and I am definitely sure that it will end up being more expensive and take twice as long as just buying the adapter for a Chevy from Marks. I just get excited about some idea and won't let it go until I have proven to myself that I can do it.
Old October 18th, 2012, 08:27 AM
I posted a thread on pirate a few years ago that had the part numbers and what not. I've also got a Range Rover with that setup in it. FWIW I would much rather have the ZF box than that 3 speed turd.
Old October 18th, 2012, 10:28 AM
RockShow's Avatar
RockShow
Ben Goodwin
1996 D1
I have read ringing endorsements of the 727 as well as not so positive opinions. The setup would go into a crawler or a little D-90 P/U so not too worried about it being a daily driver or anything. My attraction to the 727 and the Buick block would be to keep it still realitively rover but do something different. Plus I have found tons of really cheap HD rebuild kits for the 727.
I remeber reading some stuff about it on pirate and found a guy that said he would mill me a set of the adapters and then I never heard back from him.
Old October 19th, 2012, 06:54 PM
ipgregory's Avatar
ipgregory
Ian Gregory
'97 D90 ST #1008
Here is a terrible (only one I have) pic of the 3 speed that came out of my 84 RRC. I think this is the same trans/t-case set up you're talking about but its been 15yrs since I last saw it.
Old October 20th, 2012, 02:30 AM
Jake1996d1's Avatar
Jake1996d1
Jake
96 Disco/88 RRC
Im doing just about the same thing but looking at running a 350 chevy to the TF.. I'm interested to see how these turn out!
------ Follow up post added October 20th, 2012 01:32 AM ------
I am pretty sure the RV8 had an adapter to bolt to the TF 727... I'm sure Advance Adapters sells the adapter needed to run a 300/340 to a scout trans.. I know for a fact they sell one for the early 350
Old October 20th, 2012, 02:56 AM
ipgregory's Avatar
ipgregory
Ian Gregory
'97 D90 ST #1008
Not that I recall, I want to say it bolted right up. Can't remember if the Bell housing was removable and therefore rover specific but it bolted up direct to the back of the engine I think. Been a long time though like I say.
If you look at the pic of my old Torqflite above that is a rover pattern on that BH. There was no adaptor that I recall. It should be in that pic if there was as thats the whole trans/tcase set up right after I separated it from the engine. I didn't take a lot of notice of it to be honest as it wasn't going back in and was scrapped.
Old October 20th, 2012, 06:03 AM
ipgregory's Avatar
ipgregory
Ian Gregory
'97 D90 ST #1008
OK, ignore the above post and the picture further up. I think now looking at it again closer, it’s just a really, really bad pic of the ZF that I put in the truck to replace the TF with. I can’t find a pic of the TF anywhere and I want to say it was 1 piece with the BH so there probably was an adaptor. Getting old I guess...
Old October 20th, 2012, 10:20 AM
Jake1996d1's Avatar
Jake1996d1
Jake
96 Disco/88 RRC
Originally Posted by ipgregory View Post
OK, ignore the above post and the picture further up. I think now looking at it again closer, itís just a really, really bad pic of the ZF that I put in the truck to replace the TF with. I canít find a pic of the TF anywhere and I want to say it was 1 piece with the BH so there probably was an adaptor. Getting old I guess...
Yep it's a 1 piece trans and the ridges on that make it look like a ZF the TF is smooth.
Here's a pic of the different models.. The Scout model is the same as the rover but came with an adapter to the 10 spline for the LT230.
http://www.ihonlynorth.com/forums/at...-cmparison.jpg
Old October 26th, 2012, 05:56 AM
RockShow's Avatar
RockShow
Ben Goodwin
1996 D1
I found a guy in Austrailia selling what I think is the tailshaft adapter for the 727 to the RRC. I am going to email him to double check and see if there is a way to get the BH adapter or atleast the specs. Maybe these things are just lying around like weeds down there... The part number he lists is FRC5636.
ht
Steering wheel adapters Buckon37s Defender Technical Discussions 109 July 1st, 2007 09:19 PM
The 2.8 TGV and 300TDI to GM adapters are in stock OBW_Canada The Vendors Loft 5 December 14th, 2006 11:12 PM
Range Rover Sport on UK Website boshea Misc. Chit-Chat 1 December 27th, 2004 08:21 AM
The Greatest Rover Shop Ever Buckon37s Misc. Chit-Chat 2 December 22nd, 2004 01:00 PM
Camp Rover West - Utah USA chrisvonc Trip & Trail Reports 0 June 19th, 2004 12:30 PM
