Looking for a lock/key set - Defender Source
Old September 4th, 2014, 02:59 PM
samer0214's Avatar
samer0214
Samer Hijazi
1997 P38 Vitesse
I am looking for a lock and key set for an Exmoor Security Cubby Box. I am attaching pictures of the cubby box and actual lock that is currently installed on it.
FYI, both Exmoor and Rovers North couldn't help, as the box is discontinued. 2 local locksmiths couldn't help either.
Thank you.
ID:	102153   Click image for larger version
Thank you - Samer
1997 P38 Vitesse (Red)
2003 Discovery II
Defenderless, for now!
Old September 5th, 2014, 04:24 AM
samer0214's Avatar
samer0214
Samer Hijazi
1997 P38 Vitesse
Bump.
Thank you - Samer
2003 Discovery II
Old September 5th, 2014, 08:45 AM
ezzzzzzz
Mark Garrenton
These guys probably manufactured that lock. Contact them to see if they can assist you.
http://www.euro-locks.us/contact/
Old September 8th, 2014, 12:49 PM
samer0214's Avatar
samer0214
Samer Hijazi
1997 P38 Vitesse
Mark: thanks for the referral. I contacted that company and unfortunately, it's not their lock.
The search continues. Anyone have have a damaged cubby with an intact lock and key?
Thank you - Samer
2003 Discovery II
Old September 8th, 2014, 12:52 PM
Samer,
I have seen locks like that at Ace Hardware, they are for mailboxes. You could probable reuse the hook portion to make it work if they don't come that way.
Old September 8th, 2014, 12:54 PM
samer0214's Avatar
samer0214
Samer Hijazi
1997 P38 Vitesse
That would be too easy and a no brainer! I will check my local Ace. Thanks for the tip Dave.
Thank you - Samer
2003 Discovery II
1997 d90 soft-top door lock key swap d90boy Defender Technical Discussions 9 February 14th, 2012 04:49 PM
Door lock key blank gliebig Wanted 1 May 20th, 2010 03:58 PM
How do I remove a lock cylinder if I don't have the key? evilfij Defender Technical Discussions 5 May 1st, 2009 01:45 PM
Ignition switch key lock revtor Defender Technical Discussions 5 December 4th, 2006 06:32 PM
