light switch(like the dimmer switch) - Defender Source
Old May 25th, 2014, 12:23 PM
defender1844
Amit Likhyani
Need a switch for my off road lights. I am pretty sure I've seen an aux light switch that goes right next to the dimmer switch that can be used for this purpose. Does anyone have one? On that note, are there any other options that look factory if I was hallucinating when I thought I saw this?
Old May 25th, 2014, 12:39 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
PRC3432 This is the part you want it goes on the right side of the steering wheel.
Go down this page to find it http://rovahfarm.com/defenderignitionpage2.htm
I wired mine into my high beams too (to activate a relay), so when I dim my lights, my off road light go off too.
While you are at it, do this to your regular running light to remove all the amperage from you head lamp light switches. You'll be amazed at how much brighter your lights will be, simple install.
http://www.ebay.com/itm/H4-Relay-Har...55ac6a&vxp=mtr
Old May 25th, 2014, 01:39 PM
defender1844
Amit Likhyani
Jeff, where do you mount it though? On the plug opposite the ignition?
Old May 25th, 2014, 06:42 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
The spot where it mounts would be on the main body, right side, half way up, just below the wiper stalk. NOT the hole plugged with the small rubber which is lower.
ht, switch
ebay dimmer switch Broncoduecer The Flea Market 0 February 8th, 2012 06:55 PM
Dimmer Switch madcowdungbeetle Wanted 1 July 4th, 2011 05:12 PM
Dash Light Dimmer Switch Stmpede Wanted 6 November 30th, 2008 10:29 PM
Instrument Cluster Dimmer Switch madcowdungbeetle Wanted 1 May 12th, 2008 01:32 PM
WTB: D90 Dash Dimmer Switch PCRover Wanted 1 January 11th, 2008 09:18 PM
