LHD Steering Drop Arm Needed - Defender Source
Old November 6th, 2013, 12:08 PM
Looking for a LHD steering drop arm, part number QFW000030.
I'm installing power steering in my ExMOD90
If you have parts laying around I am also looking for the piping and the reservoir.
The motor is a 200TDi and the dear box is out of a Disco.
Old November 6th, 2013, 12:25 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
Originally Posted by javelinadave View Post
Looking for a LHD steering drop arm, part number QFW000030. I'm installing power steering in my ExMOD90 If you have parts laying around I am also looking for the piping and the reservoir. The motor is a 200TDi and the dear box is out of a Disco.
are you looking for d1 steering components or defender
Old November 6th, 2013, 12:30 PM
Defender
Old November 6th, 2013, 12:33 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
Dave, I think I have one, I just replaced mine. It needs the ball joint replaced, but let me see if it's still around. If it is, it's all yours.
Old November 6th, 2013, 01:06 PM
jafir's Avatar
jafir
Jafir Elkurd
What's wrong with the one from your manual box? Assuming they are both adwest boxes, the original arm should work. Part number STC1045, which SS to QFW000030, is used on both adwest manual boxes and power boxes, according to the catalog.
That's my plan at the moment anyway. Hopefully I don't find out I'm wrong like I did with the crankshaft pulley
Old November 6th, 2013, 01:23 PM
Thanks Jafir, I did not know that!
Guess I need now are the pipes and the reservoir.
Old November 6th, 2013, 04:20 PM
CDeWan
Clay DeWan
5.3L beastie
Reservoir can be had out of a classic or d1 I believe. You will neen a reservoir brackets.
Old November 6th, 2013, 05:13 PM
Will the Disco/RR bracket work?
Old December 4th, 2013, 05:26 PM
jafir's Avatar
jafir
Jafir Elkurd
So you might need to get an arm.... depends on how lucky you are. I was able to pull the disco arm off of the power steering box with no issues whatsoever. But getting the defender arm off of the manual box is kicking my butt. I went ahead and ordered a new replacement.
Old December 4th, 2013, 05:43 PM
Used the box and steering out of my D1 for my D90 build.
Old December 4th, 2013, 10:39 PM
FYI I always use two large punches as levers to remove the drop arms. This works even when pullers fail. Definitely leave the nut on, but loose, for safety.
Old December 4th, 2013, 10:58 PM
jafir's Avatar
jafir
Jafir Elkurd
Thanks for the advice. Do you just hammer the punches in between the arm the the housing of the box?
I got worried when I started reading on some of the UK sites that they resort to cutting them off!
It's coming off whole, even though I've ordered a new one. It won't win!
Old December 4th, 2013, 11:15 PM
Take no prisoners!!!!!!!!
You can always try hitting the arm with some heat and then try with a puller or a pickle fork.
Old December 4th, 2013, 11:46 PM
mongosd2's Avatar
mongosd2
Frank Rafka
01 D2 96 D1 83 110
heat destroys the seals in the box…a disco arm will work, I think we might have one in the pile, so I'll look tomorrow
how'd the engine swap go?
Old December 4th, 2013, 11:47 PM
jafir's Avatar
jafir
Jafir Elkurd
Originally Posted by mongosd2 View Post
heat destroys the seals in the box…a disco arm will work, I think we might have one in the pile, so I'll look tomorrow how'd the engine swap go?
Disco arms don't have the ball joint. I think a RRC arm would probably work.
Old December 4th, 2013, 11:55 PM
mongosd2's Avatar
mongosd2
Frank Rafka
01 D2 96 D1 83 110
yep, your right…my arm and drag link are off a disco...
Old December 4th, 2013, 11:57 PM
The manual box is a throw away from this swap so death to seals!!!
Old December 5th, 2013, 12:03 AM
jafir's Avatar
jafir
Jafir Elkurd
Whatever. I'm going to try and sell mine to some sucker with a disco that has a leaky box.
"Upgraded box. Guaranteed never to leak power steering fluid. Improved road feel."
Old December 5th, 2013, 12:24 PM
Yep, just hammer away. It can be a little tricky sometimes because the punches like to slip out.
Old December 5th, 2013, 12:51 PM
The Dro
Dro
1988 Ninety
Sent you a PM
lhd
Steering Drop Arm QFW000030 The Dro For Sale - Parts 3 September 30th, 2013 02:57 PM
Defender Steering Drop Arm - Removal SpitfireTDI Defender Technical Discussions 4 September 4th, 2013 08:18 AM
steering drop arm ball joint souza Defender Technical Discussions 20 February 29th, 2008 11:41 AM
Drop arm! TwisteD90 Defender Technical Discussions 9 July 19th, 2005 09:27 PM
Steering drop arm kellymoe Defender Technical Discussions 12 November 7th, 2004 02:07 PM
