Lhd Heater. - Defender Source
Old October 28th, 2014, 11:14 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Lhd Heater.
Oolong for a used Lhd heater. It can be old with leaking core. Any condition
Legend in My Own Mind.
Old October 28th, 2014, 08:47 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
I just rebuilt a RHD into a LHD. My metal bending skills are not the best but it worked and you can not tell it is anything other than factory after the install. I added a GM blower motor for that added whoosh.
Old October 28th, 2014, 09:26 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
This is what I am going to do. I have a page from ExPo bookmarked with someone that did it. I did have to buy a LHD blower cage tho.
Old October 29th, 2014, 06:21 AM
Abu Buckwheat
Malcolm
2005 Defender 110 TD5 Station
Registered User
PM me. I have one for sale in the for sale section.
Old October 29th, 2014, 08:50 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Message sent
------ Follow up post added October 29th, 2014 08:50 AM ------
Cool would love to see it
------ Follow up post added October 29th, 2014 08:51 AM ------
Can you post a link?
Old October 29th, 2014, 08:56 AM
Mike Sandone @ American Overland in Ct did that write up. He's a member here and I have seen the heater he did. Unfortunately the lhd blower cage is now north of $300 from Rovers North. When he did his it was a sub $50 part per our conversation.
The write up on converting the heater is here on this forum.
http://www.defendersource.com/forum/...eferrerid=3511
Old October 29th, 2014, 12:15 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Thanks Doug - that is the build I was thinking about. Between heater boxes and lower dash prices I have half a mind to start converting RHD pieces to work on LHD builds.
Old October 29th, 2014, 12:53 PM
Capt Milks's Avatar
Capt Milks
Doug,
You can buy a GM heater fan off the shelf for around $50.00. The cage is very very close and the motor is stronger than the factory LR one. You do have to modify the bolt holes and electrical connection however.
Old October 29th, 2014, 12:59 PM
Mike, should have said lhd blower motor housing - the sheet metal part is the issue not the blower motor.
Actually just looked it up and its not that terribly expensive.
http://www.roversnorth.com/ProductDe...e=0&eq=&key=it
Old October 29th, 2014, 04:15 PM
jafir's Avatar
jafir
Jafir Elkurd
For some reason there are two (or more) part numbers for the same part. One of them is ridiculous: http://www.roversnorth.com/ProductDe...e=0&eq=&key=it
Old October 29th, 2014, 05:43 PM
Yep thats the one I found previously that stopped me from proceeding. Some one has been eating a bit of Alice's mushroom on the pricing on that one.
Old October 29th, 2014, 06:27 PM
Capt Milks's Avatar
Capt Milks
The rhd blower motor has the vanes in the motor running the wrong direction when you try to move it over. It will blow some air but not much. I use "factory air part # 35333" I got it at the local auto parts store. Changing the housing over wasn't too bad but I did have to make another flange.
I also found some LHD assemblies with both the motor and the housing in the UK for about 120 pounds. Don't know if they had any in stock however.
*Rare* NAS 110 AC/Heater Assemblies For sale or trade for D90 heater/dash conversion evilfij For Sale - Parts 10 May 2nd, 2013 04:39 PM
heater matrix heater core. Naplm00 Wanted 0 December 21st, 2011 01:34 AM
200tdi block heater vs hose heater tomaco1 Defender Technical Discussions 14 December 7th, 2009 10:55 AM
LHD Heater Box Doug Crowther Wanted 1 November 14th, 2007 02:21 PM
LHD plastic underwing heater intake duct Overlander Wanted 3 December 28th, 2006 08:51 AM
