LH swivel outer housing from RHD truck - Defender Source
Old May 23rd, 2011, 09:16 AM
Jopadorr
John Dorr
59 109 hybrid
As the title says...I need a LH outer swivel housing (not the ball) from a RHD truck...will have arms forward and rear. I need this for my conversion.
Im in Delhi NY 13753- best to email me off this board at jpdorr at gmail dot com- Thanks- J
Old May 23rd, 2011, 10:02 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
i think i have left over
You are keeping it RHD right?
Old May 24th, 2011, 12:40 PM
Jopadorr
John Dorr
59 109 hybrid
knuckle housing
The truck I am building is a leafer 109 with a V8 and coiler axles made to fit a leaf sprung chassis. The LH knuckle housing from a RHD will allow me to run both tie rod and drag link up front away from the leafs.
I have to drill and ream new holes, but am pretty certain I have enough material on the arms to work with.
The LH knuckle housing from a LHD has only the tie rod provision on the rear arm- it has no forward arm. When I looked at the RH knuckle housing's forward arm which connects to the steering box there is plenty of space to allow another hole/rod. When I measured the distance from center(top pin) of the existing (rear arm) holes for the tie rods and transpose those measurements to the front arm I find that there is enough space to allow a second set of holes in the correct locations. So with a LH knuckle from a RHD I will have tow forward facing arms.
To these arms I will have to drill and ream new holes for the tie rod moving it from the rear behind the diff (and fouling on my leaf springs) to the front...or so I hope.
Please let me know what you find and what you want for it. Thanks- John in Delhi NY 13753
Old May 24th, 2011, 01:59 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
I just checked with the class and we sent it to the salvage!
Sorry, I totally forgot.
Old May 25th, 2011, 03:59 PM
You need to specify which swivel housing, there are at least two different ones that I know of. Mine have a big step at the top to make room for the big railco bush. Commonly available US Disco and RR housings do not have this.
rhd
First trip in the truck rijosho Misc. Chit-Chat 28 May 9th, 2010 09:12 PM
Equipe Swivel Recovery Points RedRhinoProducts For Sale - Parts 7 March 17th, 2006 06:01 PM
Swivel Fluid rover4x4 Defender Technical Discussions 3 October 12th, 2005 03:07 PM
Front Outer Fender Template TDI Guy Defender Technical Discussions 8 June 11th, 2004 07:32 AM
Need Left Wing outer shell vnrover Wanted 8 April 8th, 2004 12:56 PM
