Land Rover Dealer - Ignition key cut?? - Defender Source
Old December 16th, 2013, 05:19 PM
d90boy's Avatar
d90boy
keith humphreys
aka: Mr Fancy Pants
Hi All,
can someone help me with a spare ignition key?
my local LR dealership is not so helpful.
i have a client that can not find his spares and just lost his "1st" set in the snow yesterday in PA. i have the VIN, i dont mind "trying" it first then calling a locksmith if the VIN cuts the wrong key.
THANKS!!!
regards,
keith
Old December 16th, 2013, 05:44 PM
might be quicker/easier to just order a new barrel w/ keys
Mark Kellgren
KM4BOR
Old December 16th, 2013, 05:50 PM
navydevildoc's Avatar
navydevildoc
Neill Thornton
I had no problem getting a new LR3 key with just the VIN... I had to show ID and registration before they would order it though.
Is this for a 90?
Old December 16th, 2013, 06:01 PM
d90boy's Avatar
d90boy
keith humphreys
aka: Mr Fancy Pants
yes for a d-90. he service man said he could not cut it there. =(
i am trying not to replace anything as of yet for sake of ease.
Old December 16th, 2013, 06:08 PM
navydevildoc
Neill Thornton
They had to have mine shipped from the UK I think, I had to wait almost 2 weeks for it.
Old December 16th, 2013, 06:21 PM
Snow is melting ....
Try a different dealer. A lot of them do not have the tool to cut the old keys. Usually they will cut one with ID + proof of ownership
Old December 16th, 2013, 06:28 PM
d90boy's Avatar
d90boy
keith humphreys
aka: Mr Fancy Pants
i can give them a copy of the title and license - thats easy. i just need to know the dealership that will do it. =)
Old December 16th, 2013, 06:32 PM
Call the parts department of any local dealers to the guy. He is going to have to show up to get it. Probably a two day affair unless by some miracle someone has a blank.
Old December 17th, 2013, 02:12 PM
d90boy's Avatar
d90boy
keith humphreys
aka: Mr Fancy Pants
2 more tries today and no help. any land rover dealership people here??? where is MartinP. i just left you VM.
Old December 17th, 2013, 03:42 PM
I had the same problem last year... Getting ready for an event, and my 2 youngest lost both sets of keys for my 90 (in the house). I called my buddy that works for LR corp, and all the local dealers, no luck. I found both sets 2 weeks later.
The 90 keys were cut by hand with a plyers type tool (dial vin in). One of the tech had one, but I could not locate a blank key...
Can you borrow a metal detector for him?
Old December 17th, 2013, 03:46 PM
Just borrow one from one of the trucks on the lot. Don't they all pretty much work in any Defender?
Are you having trouble finding a blank, are you having trouble finding a dealer who can supply you with the correct pattern, or are you having trouble finding a dealer that can cut the steel? Or is it all three?
Old December 17th, 2013, 04:08 PM
I believe he needs the key code.
Old December 17th, 2013, 04:30 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
Keith,
Give Joe Fuentes at Land Rover Winnetka a call at 847-446-6665 and tell him that I told you to call him. I know we have the tool here, we may have to order a blank, but I've watched them cut them here, or you can probably order a pre-cut one from the factory as well I would imagine.
-Andrew
Old December 17th, 2013, 04:59 PM
d90boy's Avatar
d90boy
keith humphreys
aka: Mr Fancy Pants
thanks all.
i have the blank
i have the code
the blanks is aluminum
thanks andrew i will call him in 5. thanks!!
Old December 17th, 2013, 05:49 PM
Reese_D90's Avatar
Reese_D90
Reese
97 D90 ST and 93 D110
For future reference....
Went into the neighborhood home depot, told them I had a ford, matched the key. Works like a champ.
NAS 1993 D110 CDN #11/25
1997 D90 ST #1953
2006 Range Rover
1997 D90 SW #701 (sold)
1995 D90 ST (sold)
Old December 17th, 2013, 06:14 PM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Originally Posted by Reese_D90 View Post
For future reference.... Went into the neighborhood home depot, told them I had a ford, matched the key. Works like a champ.
That's slick.
Old December 17th, 2013, 10:44 PM
navydevildoc
Neill Thornton
If that's the case, you have solved the Key Blank Conundrum.
Does the key have any part numbers or other such info?
Old December 17th, 2013, 10:47 PM
Ilco LF17/X157
Also discussed here:
http://www.defendersource.com/forum/...ight=Ilco+LF17
Old December 18th, 2013, 07:00 PM
FYI I work for a Land Rover dealership if you ever need anything in the future.
Old December 20th, 2013, 06:05 PM
d90boy's Avatar
d90boy
keith humphreys
aka: Mr Fancy Pants
calling ron. my last hope did not work this week. do you know any mechanic near new hope, pa that can swap out the ignition?
email me please: keith @ copley motorcars . com
thank you!!
land rover
Help! Key Stuck in Ignition - Electrical Problem wadaman Defender Technical Discussions 15 June 19th, 2009 04:38 PM
replacing ignition key - 94 snosrfr Defender Technical Discussions 10 June 1st, 2005 01:41 AM
Dumb ignition/door key question, did search first Neo Defender Technical Discussions 15 May 30th, 2005 07:10 PM
110 roof, ignition key code, windshield frame, etc... martym Defender Technical Discussions 7 February 24th, 2005 01:45 PM
