Kickdown Auto brackets - Defender Source
Old January 31st, 2016, 09:17 PM
rayfi's Avatar
rayfi
Derek Moeller
110
ERR4897 Lever -
ERR1604 Bracket -
Looking for the brackets for the kick down on an automatic 300tdi.
Old January 31st, 2016, 09:23 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
I searched every supplier on the east coast last year; nobody had 'em.
Got them from Ashcroft and they were pretty quick.
Make sure you have the correct length cable, too.
Ashcroft Transmissions
Rent my
Old January 31st, 2016, 10:06 PM
speedpin's Avatar
speedpin
1985 130 Gen IV
If you order from ashcroft....
I am finalizing an order with ashcroft tomorrow that will ship in 2 weeks or so if you want to throw them in my crate. I will get them to you once it arives. Might save you some $ if you can wait.
~ Semper Fidelis ~
Old February 1st, 2016, 12:22 AM
rayfi's Avatar
rayfi
Derek Moeller
110
Safari has new. I just thought I would check and see if any used ones are floating around.....
Thank you for the offer.
Old February 1st, 2016, 06:01 AM
speedpin's Avatar
speedpin
1985 130 Gen IV
No problem.
~ Semper Fidelis ~
Old February 1st, 2016, 07:28 AM
Probably same part used on RRC and D1 if you are willing to invest time to save $$
Old February 1st, 2016, 07:48 AM
Kevin88RRC's Avatar
Kevin88RRC
Kevin Keith
1988 RRC
Can anyone confirm this? I have an RRC w/ 3.5 I could pull from... but I hope to have it hauled away in a day or two (finally).
Old February 1st, 2016, 08:18 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
huh? ...the brackets aren't truck-specific, they're motor-specific...
Rent my
Old February 1st, 2016, 08:58 AM
huh? ...the brackets aren't truck-specific, they're motor-specific... .
Interesting. Googling the pn suggested in several vendor sites the opposite
Old February 1st, 2016, 09:12 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Oh, I'm not saying I'm correct-- I just did this conversion a year ago and nobody I called in the states had the brackets for a 300.
Ashcroft came through quickly.
I also found that someone had changed my cable on the ZF, presumably to be helpful.
But the diesel requires a longer cable than the V8.
So I had to change it in situ... not as much fun.
Ashcroft Transmissions - cable
Rent my
Kickdown cable? Nomar Smaller Projects 19 August 20th, 2014 09:33 PM
300tdi kickdown brackets Nomar Wanted 3 April 30th, 2014 08:59 AM
Kickdown cable for 300tdi ZF gearbox Davin Wanted 0 March 2nd, 2013 09:14 AM
Kickdown cable on ZF, DOH! RedRhinoProducts Defender Technical Discussions 0 November 13th, 2004 10:32 AM
Installing new kickdown cable...anyone? P1CR Defender Technical Discussions 4 December 19th, 2003 01:15 PM
