ISO: Feedback on LR3's - Defender Source
Old June 6th, 2016, 11:11 AM
Jbirdlott's Avatar
Jbirdlott
Jason
1985 LR 90 200TDi
I have a friend looking to purchase a LR3. I've seen a few posted from time to time. I didn't know what year to tell him to buy and or avoid. Can anyone comment on the best year to buy!? What issues they have or are known for...
Thanks much for your time,
Jason
Old June 6th, 2016, 11:12 AM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
Great ride & get used to 16.4 MPG.
Old June 6th, 2016, 11:20 AM
Jbirdlott's Avatar
Jbirdlott
Jason
1985 LR 90 200TDi
ha ha I bet. Thanks!
Old June 6th, 2016, 11:42 AM
Ray_G's Avatar
Ray_G
Ray Gerber
There is no bad year, anecdotally avoid the 05 but that's more now a facet of mileage and maintenance. Known issues are nowhere near previous generations of truck so be mindful not to think of them akin to Dii head gasket failures, P38 BeCM issues, Defender oil lines and spontaneously corroding cross members as the drivetrain and such has seemed to bear out far better.
They will eat tires, brakes, lower control arms-b/c they are heavy.
They will need a compressor rebuild/update at some point as the system ages.
Some can have dif issues but see my note above.
They love good voltage so a weak battery will cause fits.
Check the passenger side floorboard for water from one of a few sources (a pillar, sunroof drains, pollen filter). Corroded wiring there can cause issues.
All told they are fantastic trucks that can be had at good $$$ these days, just find one with a good history and don't be scared to pass several by as there are plenty of them out there.
R-
R
Old June 6th, 2016, 12:37 PM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Notice an 05 on eBay with 8k original miles. Think they were asking $25k.
Old June 6th, 2016, 01:15 PM
WeBeCinYa's Avatar
WeBeCinYa
WeBeCinYa
94 ST #84
Lots of clean examples out there, and some that have been rode hard and put up wet. I'd have a dealer or Indy shop look them over closely for a PPI. I have a used 06 with 75k miles and it's solid.
Here is what appears to be a clean truck...
https://washingtondc.craigslist.org/...620720885.html
1994 Defender 90
2006 LR3 SE
1996 Discovery I (sold)
1991 Range Rover Classic (sold)
1995 Range Rover Classic (sold)
2006 LR3 SE (sold)
Old June 6th, 2016, 01:43 PM
Al Blue4.6l's Avatar
Al Blue4.6l
Allen
2006 LR3
Definitely keep an eye out for water - I've had the front sunroof drains clog up on mine and the AC vent drains decided to clog up on a trip over the weekend - I unclogged after I got back yesterday and the floor is already dry fortunately.
The front (at least) air shocks are likely to need replacing at around 10 years/100K.
As mentioned, the differentials can be an issue - the locking rear diff, if equipped, is more expensive to replace. LR has gone through several iterations of breather caps for the front diff. I'd listen carefully for whining diffs on a test drive.
Also, the transmission really should have the fluid changed at around 100K. Its a bit of a job.
Old June 6th, 2016, 02:09 PM
WeBeCinYa's Avatar
WeBeCinYa
WeBeCinYa
94 ST #84
Couldn't agree more. I heard a whining rear diff on mine during test drive. Had PPI done, sure enough it was rear diff going out. Seller had it replaced prior to my purchase, which was huge cause it's not cheap.
1994 Defender 90
2006 LR3 SE
2006 LR3 SE (sold)
Old June 6th, 2016, 02:13 PM
AdamSanta85's Avatar
AdamSanta85
91' D90 200TDI
That seems like a lot of truck for the money. Tempting.
Old June 6th, 2016, 02:15 PM
Jbirdlott's Avatar
Jbirdlott
Jason
1985 LR 90 200TDi
Thanks gents this is the helpful info I knew you'd be good for! Cheers
Old June 6th, 2016, 02:31 PM
waveridin1959's Avatar
waveridin1959
Brian Jones
1995 D-90 ST #2892
Dont worry about the edges of the Steering wheel that curl up. I've havent seen one that hasnt done it. Also, the Parking Brake can sort of get stuck on. They are unfortunately electronic. I would like to know who thought that was a good idea.
1995 Defender ST
1996 Discovery SE7
2008 LR3 HSE - Wife's
Old June 6th, 2016, 02:54 PM
Al Blue4.6l
Allen
2006 LR3
agreed on the steering wheel cover. Maybe we'll all get them replaced by Takata...
everyone is moving to electronic parking brakes for packaging reasons.
ISO: 5 boost alloys in good shape Mighty Wanted 3 January 29th, 2010 01:42 PM
LR3-Any Feedback? saber6 Misc. Chit-Chat 14 June 30th, 2007 03:27 PM
Iso Rear Door Chequer Plate willtillery Wanted 2 April 10th, 2005 02:11 PM
ISO: ANY PARTS for NAS safety devices roof rack NASD90 Wanted 3 February 28th, 2005 01:22 PM
ISO: Rear door subwoofer box NASD90 Wanted 2 August 23rd, 2004 08:59 AM
