I need to borrow a diesel compression test kit - Defender Source
Old August 4th, 2014, 09:11 AM
anyone have one they can loan me? I want to check my compression health to try to chase down a mistery oil leak I'm having trouble finding. 300 tdi fittings work for me.
Mark Kellgren
KM4BOR
Old August 4th, 2014, 11:36 AM
richord
Richard Ordowich
1987/D90
I would gladly let you borrow mine but considering I only paid $40.00 for mine from Harbor Freight I think getting it to you would be more expensive than buying one. Although if you happen to be in the NJ area, you could drop by and I would be happy to do the test at my place.
I too am chasing oil leaks on my 2.5 TD, 19j engine. The compression was fine in all cylinders around 420 PSI. I just purchased a oil leak tracer kit consisting of a UV Florescent dye you put into the oil to trace leaks.
Old August 4th, 2014, 11:50 AM
That's great info! I know harbor freight had the kit but wasn't clear if the kit had the right adapters for the TDI glow plug threads. Can anyone confirm if the 19J glow plugs have the same threads as the later tdi's?
I'm going to get that tracer kit. Where did you get it? I've seen the UV dies for AC and coolant at NAPA and Autozone, but never saw any for oil.
------ Follow up post added August 4th, 2014 11:52 AM ------
Never mind about die. I see now bunch of stores have it. Guess I never noticed.
Mark Kellgren
KM4BOR
Old August 4th, 2014, 11:57 AM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
Yes - depth changes
Old August 4th, 2014, 12:01 PM
richord
Richard Ordowich
1987/D90
The kit from Harbor Freight I purchased: Diesel Engine Compression Tester 12 Pc contains a series of adapters.
The dye I bought was on Amazon:
Tracer Products TP34000601 UV Fluorescent Leak Detection Dye - Set of 6
I plan to use the leftovers to determine my "leaks"
Little more research reveals that the 300 TDI has a 10x1.0 thread. This harbor freight kit below has 10x1 adapter in it, which is also used by Navistar, VW TDI's and Mercedes.
http://www.harborfreight.com/12-piec...ter-93644.html
Thanks for the tip Richard! I should have googled harder!
Mark Kellgren
KM4BOR
diesel, kit
Compression Test Results 2.5TD richord Defender Technical Discussions 1 July 18th, 2014 10:51 AM
Diesel compression tool. Roverlab Misc. Chit-Chat 1 May 17th, 2014 11:20 AM
Normal Compression Test reading wantone Defender Technical Discussions 5 January 30th, 2013 03:06 PM
Need to borrow a OBD reader- Denver aosias Defender Technical Discussions 5 July 1st, 2010 09:27 PM
Compression Test Results... need help interpreting them martym Defender Technical Discussions 12 March 3rd, 2005 09:46 PM
