Help! need STC934 glow plug harness - Defender Source
Old February 16th, 2009, 12:22 PM
cabell's Avatar
cabell
Cabell Crowther
Anyone have one? These are on back order from RN and I need one now. It is the harness that plugs into the glow plug harness and goes to the ignition switch and glow plug light.
Old February 16th, 2009, 01:14 PM
you sure about that part number ? Pulls up as a vacuum pipe
try this part #
Product Code: PRC6083 PRC6083 WIRING HARNESS GLOW PLUG 2.5 TDI (G)
Our Price: $45.77 Brit-Car
I know you have seen it but here is the pamphlet from the now discontinued factory 200 Tdi Retro-fit Kit.
It lists all the part numbers. Figured its ok to post since Rover no longer sells the kit ????
http://landrover-online.dk/L-R%20WSM...0Tdi20info.pdf
Old February 16th, 2009, 01:18 PM
cabell's Avatar
cabell
Cabell Crowther
Not sure why it comes up as a vacuum pipe. George said he could not find the # at all. Anyway, STC934 is correct and it comes up in the RN system. It is a sub harness and plugs into PRC6083.
Old February 16th, 2009, 01:29 PM
you're right. From Nicks Jungle:
Cable STC 934 plugs into PRC 6083 and the black/white wire screws to the bulkhead. At the other end of it the white/red cable goes to the white/red on the back of the igniton and the connector with both the whites goes to the white on the the ignition, they both have piggyback connectors. The yellow/black wire goes to the spade on the bottom of the orange looking square light on the warning panel and the other white goes to the top spade.
http://www.nicksjungle.co.uk/200tdic...s/stc934-1.jpg
Old February 16th, 2009, 04:34 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
Cabell or Doug if you come across a place that has them in stock let me know, I will need that part for my 2.5 NA to 200tdi conversion
thanks for posting that DOC Doug
Old February 16th, 2009, 09:09 PM
Dave,
Anytime I have a ton of stuff saved in my favorites. It would seem as though Jim C has more however.
Cheers,
Old February 16th, 2009, 09:38 PM
Originally Posted by Maryland 110
Dave,
Cheers,
Its actually worse than that - I've got an STC 934D sitting in my garage. Cabell - can I count on you to replace mine if I send it to you? Is it NLA?
Old February 17th, 2009, 12:50 AM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
This looks like it would be incredibly easy to make, why not just do that and save yourself some money and time (waiting for shipping)?
Old February 17th, 2009, 11:53 AM
cabell's Avatar
cabell
Cabell Crowther
Jim,
I'll glady replace yours when the new ones come in or buy yours and you can order directly...whatever makes you happy. RN said it was on back order from LR, but not NLA, although its seems a few things I have been after lately are NLA. I'm happy to double check with RN on availabilty, but I usually don't find out something is on backorder until 2 weeks go by and I call.
Let me know. Thanks.
Old February 17th, 2009, 12:20 PM
Hey Cabell - I can send it out to you no prob, but would prefer to do a simple swap since the prices often change when a new shipment arrives. As of a few years ago it was only a 26 dollar part, but I'd rather you get stuck with the price change and not me!
PM me an address (not a PO box) and I'll fedex the thing to you. Need a phone number too for FedEx.
Old February 17th, 2009, 03:19 PM
cabell's Avatar
cabell
Cabell Crowther
Well Jim,
I wanted to verify with RN that this is going to be available and they have just called to tell me it is now NLA. So.....thanks for your generous offer but I am unable to replace yours. Again, a big thanks for trying to help.
Anyone else have one?
Old February 17th, 2009, 03:24 PM
Why doesn't JimC post a pic so you can remake one?
Old February 17th, 2009, 03:33 PM
Wilco!
Old February 17th, 2009, 03:41 PM
cabell's Avatar
cabell
Cabell Crowther
Gracias.
Old February 17th, 2009, 04:48 PM
Ok, a bunch of pix. If its not clear, let me know. The only tricky part is in sub-area 3 where the white wire goes to the lead (A), comes back into the harness and doubles back (B) finally leading out to C.
Name:	Glow Plug Harness A.jpg
ID:	17832   Click image for larger version
Name:	Glow Plug Harness B.jpg
Name:	Glow Plug Harness 1a.jpg
ID:	17834   Click image for larger version
Name:	Glow Plug Harness 1b.jpg
Name:	Glow Plug Harness 2a.jpg
ID:	17836   Click image for larger version
Name:	Glow Plug Harness 2b.jpg
Name:	Glow Plug Harness 3a.jpg
ID:	17838   Click image for larger version
Name:	Glow Plug Harness 3b.jpg
Old February 17th, 2009, 09:15 PM
cabell's Avatar
cabell
Cabell Crowther
Beyond the call of duty.....thanks very much JimC.
Old February 17th, 2009, 09:23 PM
Other than the big connector (which you could just use some bullets instead) it looks pretty easy to make.
Old February 17th, 2009, 10:13 PM
Yeah, totally easy to make. There are 2 gauges of wire in the harness, "normal," and "fatter" for the brown wire and the 10 inch one that goes to the glow plugs.
The relay plug itself is just 3 different widths of spade connector, other than that, the other one, like evil said, could just be made with bullets.
HTH
Old February 20th, 2009, 05:09 AM
diesel_jim's Avatar
diesel_jim
Jamie Austin
I may have one (or at least very similar) here (in the UK)....
I've certainly got that large socket with some brown wire coming out of it, so you could make up the rest of the loom.
I'll have a look tonight when i get in from work.
your's FOC (i've now built my Td5 so don't use Tdi stuff anymore)
PRC6083 is still shown on microcat as available (see attachment) @ 38.76 UKP (plus vat)...looks like it's got the big brown wire (that feeds the glowplugs) and the relay/timer socket, and the small lead that plugs into the main ignition bit.
Is this the part you need?
http://img.photobucket.com/albums/v1...im/PRC6083.jpg
Old February 20th, 2009, 08:33 AM
Jamie he has 6083. He was looking for the bit/harness that goes to the ignition switch and glow plug lamp on the binnnacle.
Glow plug wiring differences ... Retrofit Defender Technical Discussions 44 January 16th, 2012 10:44 AM
EFI harness plug rover4x4 Defender Technical Discussions 4 December 6th, 2009 08:04 AM
Pin-out for the PRC 6913 glow plug relay? dmarchand Defender Technical Discussions 7 July 10th, 2007 05:51 PM
Glow Plug Relay Michael Defender Technical Discussions 1 March 16th, 2006 02:28 PM
LR Glow Plug relay temp? dmarchand Defender Technical Discussions 0 June 9th, 2004 01:42 PM
