Heat Pipes?? - Defender Source
Old March 26th, 2013, 03:26 PM
geoellis's Avatar
geoellis
George
1995 D90 #2904 - BB
Heat Pipes??
Where can I get the heat pipes that run across the top of the left valve cover? I've searched around, but been unable to find them. Also, what is the part that's attached to the firewall?
I want to swap out these corroded components. Truck runs great, but the look in the engine bay leaves much to be desired.
1997 P38 4.6
1998 P38 4.0
2011 LR4
Old March 26th, 2013, 03:42 PM
The Dro
Dro
1988 Ninety
I looked for a while for them.
I removed mine, used sandpaper and painted with KBS Coating.
Old March 26th, 2013, 04:45 PM
geoellis's Avatar
geoellis
George
1995 D90 #2904 - BB
Seems the way to go. What color did you use?
I suppose powdercoating is a feasible option as well.
1997 P38 4.6
1998 P38 4.0
2011 LR4
Old March 26th, 2013, 11:21 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
Part on the firewall is your brake portioning valve.
Old March 26th, 2013, 11:56 PM
The Dro
Dro
1988 Ninety
Flat Black.
Old March 27th, 2013, 10:19 AM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
Blasting then powdercoating is nice, sandpaper or wire brush then paint works too but sometimes they are so rusted you may be better off with replacements. Take a good look inside when you get them off for rust.
Old March 27th, 2013, 11:21 AM
geoellis's Avatar
geoellis
George
1995 D90 #2904 - BB
Leaning towards powdercoating, but if anyone has a set their willing to part with let me know.
1997 P38 4.6
1998 P38 4.0
2011 LR4
Old March 27th, 2013, 11:23 AM
jafir's Avatar
jafir
Jafir Elkurd
I think one of the parts is ERR5474. I think that is the one without the bleeder. I'm having trouble looking them up, so don't hold me to that.
EDIT: actually that might be just for 4.0.... not 3.9...
------ Follow up post added March 27th, 2013 10:27 AM ------
Ok. ERR319 is both pipes, with the bleeder....
Excessive heat in driver side foot well Chris Vitale Defender Technical Discussions 14 August 23rd, 2008 01:03 AM
Heat insulation blankets kellymoe For Sale - Parts 1 July 13th, 2005 04:54 PM
'97 D90 external gearbox cooler pipes. kiphartzell Defender Technical Discussions 0 March 29th, 2005 11:51 AM
strange heat issue jabber Defender Technical Discussions 15 March 6th, 2005 05:42 PM
Heat question Campbell Defender Technical Discussions 8 January 3rd, 2005 08:58 PM
