Fuel Tank Needed - Page 2 - Defender Source
Old August 17th, 2010, 10:33 AM
founD90's Avatar
founD90
Dr. Gonzo
1994 D90 #48
The leak is on the forward facing side of the tank, 3/4 up. It's a 1" long indentation (i.e. no hole) that had an epoxy putty patch on it. My best guess it that the patch was there for at least 4-5 years, including all the time the truck just sat outside.
I JB Welded it last night. We'll see how it looks tonight.
Jim: Somewhere along the way as I was contemplating the truck someone told me parts were plentiful! I kind of assumed that while obscure, something like a plastic gas tank would be relatively easy to find. Alas, no....
Old August 17th, 2010, 01:45 PM
bjf's Avatar
bjf
barry f
94 ST #395
I just looked at your pics. Did the tank slide forward to give rub? Weird spot to have a leak.
Old August 17th, 2010, 01:53 PM
founD90's Avatar
founD90
Dr. Gonzo
1994 D90 #48
My guess is that the PO did it when he replaced the tank/pump/lines/plate. I bet he had some trouble getting it into place, or put it in wrong or tried to force it or maybe he just dropped it - who knows. He probably figured it out after it was installed. It doesn't look like wear related damage, looks like one bad unlucky smack.
fuel, fuel tank
I am dropping the fuel tank and I have a couple of questions, help QUEST Defender Technical Discussions 24 September 26th, 2009 03:26 AM
Calling all diesel guys - Biodiesel??? cbass Defender Technical Discussions 47 January 31st, 2006 11:18 AM
Leaky Fuel Tank cbass Defender Technical Discussions 12 June 2nd, 2005 04:50 PM
Air filters and a bad fuel tank valve thingy! RickM Defender Technical Discussions 1 August 9th, 2004 03:29 PM
