Fuel Label - Defender Source
Old May 22nd, 2012, 11:40 PM
knab's Avatar
knab
Brandon Donald
97 ST, few RRCs, P38 HSE
Fuel Label
I am looking for the UNLEADED FUEL ONLY label that goes under the gas cap. The NAS parts CD and microcat show MWC2698. I ordered that, but the label is about 3.1" long, which is quite a bit bigger than the original. Does anyone have a new label that is the correct size? Or a part number? I know it is a little OCD, but I can't help it.
Old May 23rd, 2012, 11:10 AM
i got one from roversnorth
Old May 23rd, 2012, 01:19 PM
knab's Avatar
knab
Brandon Donald
Phillip,
Did you get this one?
http://www.roversnorth.com/p-10381-l...aded-fuel.aspx
I didn't see that option when I ordered the set of labels that I ordered, which was a set of labels for catalytic convertor warnings.
Was the size of the one you order the same as the original (i.e., a bit smaller than 3" in length)?
Thanks for the help...
Old May 23rd, 2012, 02:16 PM
triple9music's Avatar
triple9music
Chad Davis
1984 Defender 90
I got one from rovers north but its one for diesel only. Small kine.
Old May 24th, 2012, 03:21 AM
mcoleman762's Avatar
mcoleman762
Mike Coleman
94 D90 ST/95 D90 SW/83 110
The label that you linked to at RN is the correct short length fuel label. Well, at least it was a direct replacement for the one on my '94 and '95. I'm going to guess it's the same for a '97 as well.
Cheers,
fuel
