Fuel filler assembly - Defender Source
Old December 21st, 2015, 11:57 AM
toad's Avatar
toad
Cutter
If anyone has one of the more modern plastic gasoline fuel fillers w cap used let me know. I have the older metal with pull out filler sleeve but the two prong metal cap doesn't seal well so gas leaks out when I go around corners with a full tank. I'd consider any filler setup actually that doesn't leak.
Old December 21st, 2015, 12:14 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
Have fitted a new seal to the cap, maybe tweek the prongs a bit to get to fit tighter, don't forget the cap is vented so if the tank is Ww'ed you will get some spill
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
assembly, fuel
109 rear fuel tank filler assembly bcourtney Wanted 7 June 18th, 2014 02:35 PM
Clutch box assembly, Fuel Pedal assembly tomaco1 Wanted 1 April 29th, 2012 11:36 AM
Source for fuel filler hose D90user Defender Technical Discussions 24 October 22nd, 2009 04:12 PM
Air intake hose, fuel filler hose and neck SafariHP The Vendors Loft 0 May 18th, 2008 08:52 PM
fuel filler hose mattdh Defender Technical Discussions 2 October 31st, 2003 08:17 PM
