Fuel Catch Tank for NAS 110 - Defender Source
Old March 20th, 2009, 08:27 PM
61rover's Avatar
61rover
John Crouse
Looking for that thing that goes up under the right rear fender. LR part #ESR2066. Mine is so badly rusted fuel runs out if I fill the tank.
Old March 20th, 2009, 08:46 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
Yeah, mine disintegrated in my hands when I removed it. They are awfully expensive new. ECR said most of them come in like that, so its hard to find them used. Best of luck finding a good second hand one though. You might check with Dale...
Old March 21st, 2009, 11:00 AM
rovertrader's Avatar
rovertrader
Dale
Sorry, only had the one- they are like hens teeth used...
Old March 22nd, 2009, 09:19 PM
How much it is worth to you?
Ron
Old September 24th, 2009, 08:42 PM
Is there any chance this can be replaced with the little vapor separator from the d-90? I'm expecting the answer is "no" but I thought I'd float the question. Mine was disintegrated also, so I'm thinking of maybe getting a stainless hotrod radiator overflow tank and making it work, but before I got to real effort I'd sure like to know what others have done.
Old September 25th, 2009, 01:45 AM
It does very little.
Use a disco I one.
Old September 25th, 2009, 03:34 AM
pendy's Avatar
pendy
jim pendleton
89'd90
I probably have a few of them around.
legend in my own mind
Old September 25th, 2009, 06:55 AM
Thanks Pendy - I've got one of the d-90 sitting around, so I thought I'd verify whether or not it will work. If it won't (and I might just try it) I'll get back with you about raiding your stash.
Old September 25th, 2009, 11:24 AM
bjf's Avatar
bjf
barry f
94 ST #395
Since people are pulling this apart does anyone know what this is?
http://www.flickr.com/photos/barryrides/3869293936/
Ron said that this vapor tube should connect to the front along the frame rail but I see nothing where it would do that and it did not fall off anywhere.
Old September 25th, 2009, 11:36 AM
I believe that's just the breather. Little one-way valve allows air in, but not out. The platic unit on the d-90 has a similar piece.
Old September 25th, 2009, 03:32 PM
bjf's Avatar
bjf
barry f
94 ST #395
so the way it is just hanging is normal?
110, fuel, nas, nas 110
I am dropping the fuel tank and I have a couple of questions, help QUEST Defender Technical Discussions 24 September 26th, 2009 03:26 AM
Calling all diesel guys - Biodiesel??? cbass Defender Technical Discussions 47 January 31st, 2006 11:18 AM
Leaky Fuel Tank cbass Defender Technical Discussions 12 June 2nd, 2005 04:50 PM
