Front Sway Bar Spacers and Disconnects - Defender Source
Old February 2nd, 2012, 02:37 AM
CDeWan
Clay DeWan
5.3L beastie
Looking for possibly a 1-2 inch spacer to fit between the sway bar mount and the frame. No I don't want to run it with out the swaybars. My driveshaft is hitting the swaybar upon jacking up the car which I believe will do the same thing as the front articulates offroad.
Also looking for a set of 4 disconnects. Not the cheapy go to the hardware store and buy a big pin and cotter pin set up but the kind that can easily be connected and disconnected on a flat surface.
Thank you!
Old February 2nd, 2012, 09:39 AM
rovertrader's Avatar
rovertrader
Dale
Clay- the JKS can be made to work with minimal alteration and are adjustable.
Old February 2nd, 2012, 05:16 PM
CDeWan
Clay DeWan
5.3L beastie
disconnects
Dale,
You're talking about the disconnects correct , don't mean to be stupid. Where can I get the JKS' and are they made for rovers or for heeps? What do you think I would need to do to get them to work. Thank you!
Old July 13th, 2017, 07:23 PM
defender1844
Amit Likhyani
Just noticed this on my front sway bar. Does someone make a spacer?
Old July 13th, 2017, 11:59 PM
emah's Avatar
emah
Ed Mah
1993 NAS D110
Clay Toddcosuspension.com and Rovertym's make them.
Old July 14th, 2017, 01:19 AM
defender1844
Amit Likhyani
Thanks Ed. Kensington in Vegas fabbed something up.
Old July 14th, 2017, 01:23 AM
emah's Avatar
emah
Ed Mah
1993 NAS D110
My pleasure Amit.
ac, disco
Swap Bar Quick Release 1of40 Defender Technical Discussions 15 June 22nd, 2006 01:58 PM
