Front radius arm - Defender Source
Old June 10th, 2013, 01:48 PM
jafir's Avatar
jafir
Jafir Elkurd
Front radius arm
I've been working on putting D1 axles in my 90. I've got the rear in, but now I'm starting to think about the front. The donor axle came complete with arms and most of the steering, which I won't be using. BUT one of the arms, the left one, is bent very badly.
So does anyone have a late style radius arm? The D1 was a 1999.
Old June 10th, 2013, 02:02 PM
transientmechanic's Avatar
transientmechanic
1972 SIII
Why are you installing the Discovery front axle anyways? There is no appreciable upgrade there... if anything you are downgrading the size of the CV joints, getting a (theoretically) weaker knuckle casting, and smaller brakes...
Old June 10th, 2013, 02:08 PM
jafir's Avatar
jafir
Jafir Elkurd
All valid points. The main things I was trying to gain are disc in the rear, 24 spline axles to make upgrades or trail spares easier, and the ability to run alloy wheels if I want.
My 90 is pretty old, so the brakes don't appear to be any bigger than the Disco, and if they are, I'll just swap them over. At some point I'll probably get later defender style calipers with vented rotors.
Old June 10th, 2013, 02:14 PM
On teh rear axle, have you looked at what is there first? Many ex-MOD 90s have 4 pinion, 24 spline rear diff with heavy duty halfshafts. These are much better than Discovery axles.
As stated, you are putting in a weaker front axle. Both the early and late axles can be upgraded for the same cost, so I'm not sure what you are gaining.
Old June 10th, 2013, 02:21 PM
transientmechanic
1972 SIII
If you're looking for a strength upgrade to 24 spline you are not going to gain anything with the Discovery parts. The weak link in your current setup would be the open diff carrier. The weak point in the Discovery setup is the CV joint.
To upgrade the Discovery axle, you will buy a new diff, new inner axles, and new CVs. While still retaining the weaker hub and stub axle setup.
To upgrade what you already have, you will just buy a diff and inner axles.
If you want the cheapest way out, take the 4-pin 24 spline rear diff out of your original 90 rear axle, and install it in the front with new inner shafts. This would be the strongest open-diff front axle setup possible!
Old June 10th, 2013, 02:30 PM
Yes, that is a good upgrade path on an ex-MOD with a HD rear axle.
1) Locker in the rear. Keep the stock halfshafts. They are pretty decent.
2) Put rear HD diff into front with aftermarket inner shafts. You are now strong enough for most people.
3) If you need more, then aftermarket rear shafts and CV joints.
I know a lot of people really want rear discs, but it will not make any difference to the braking performance. You should check and see what calipers are on the front. Depending on age, they may have the small pistons. Changing to the ones that are in 110s and most later 90s with the larger pistons is a good braking upgrade.
Old June 10th, 2013, 03:05 PM
jafir's Avatar
jafir
Jafir Elkurd
Those are all good suggestions. I'll check for the 4 pinion diff in the old rear axle, to put in front. I'm still going to keep my rear discs axle, because I've already done it. And I HATE working on drum brakes. I'm not concerned much with if the discs will stop me better or not.
Old June 10th, 2013, 03:09 PM
OK. If you were comparing a normal car disc to a normal car drum, I would agree...
But 90 rear drums are easy to work on as they do not have self adjusters. It is certainly less work to overhaul them than with the LR discs as the hub needs to come off to service or replace the rotor.
Also keep in mind the Disco rear halfshaft are quite weak in comparison to the HD shafts on the 90. If you off road, take it easy.
Old June 10th, 2013, 03:21 PM
transientmechanic
1972 SIII
The Discovery (hate calling them "Disco") disk brake rear axle upgrade is nice because the brakes are easier to clean. Drums pack with mud and grit pretty badly under the right circumstances.
Old June 10th, 2013, 03:22 PM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
On the flip side, d1 axles are cheap. You can pick up used HD 24 spline shafts from a D1 pretty easily. Same for ready to drop in regeared and/or locked 3rd members. Finding alloys or wheel spacers that simply fit over the D1 hubs is easier. You can buy brake parts locally, and get hub seals and other parts without having to decipher microcat.
Old June 10th, 2013, 03:31 PM
transientmechanic
1972 SIII
The "ready to drop in" third members will fit the 90 axles just as well.
Brake parts and seals are a no brainer as well, you just have to know what you have.
Old June 10th, 2013, 03:38 PM
Yes, the seals are the same. The bearings are common. The brakes are the same as a Series LR, so cheap and easy to find. The hub bearings are spaced farther apart and stronger...
Old June 10th, 2013, 04:15 PM
crown14's Avatar
crown14
Verticalscrote
There are "advantages" either way for sure.
FWIW (not much), I would swap in D1 axles if I bought one of these. But I'm biased, disco stuff I have already and I'm sure I could sell the take off parts to you guys. Assuming they hadn't already been swapped out for who knows what at some point in the past 25+ years, then painted red blue purple, or neon orange. If the truck came with Salisbury then it's a different story of course.
Old June 15th, 2013, 09:59 AM
jafir's Avatar
jafir
Jafir Elkurd
I guess I don't have to worry too much about the stuff I'm taking out. It's 10 spline.
Old June 15th, 2013, 11:15 AM
Could have told you the old stuff is 10 spline. You tell just from looking at the hub. I've been down the exact road you are on. Is your truck RHD?
I swapped out the whole rear axle on mine because I was putting in 24 spline thirds with ARBs and none of the 24 spline stuff would work with the old rear axle.
On the front the 24 spline axles and CV's didn't work with the 10 spline axle's hubs and stub axles so I swapped out the hubs, stubs and spindles from the 24 spline disco front axle.
Couldn't put the whole disco front axle under the car since it was LHD and I didn't have a RHD knuckle to make it work in my truck.
Eventually would like to put my AEU2522 CVs back in there with some stronger 24 spline halfshafts. and ditch the spindly 24 spline stuff.
Old June 15th, 2013, 11:30 AM
jafir's Avatar
jafir
Jafir Elkurd
Fortunately it's LHD, so my discovery front axle should bolt right in, well at least now that I have a new radius arm that's not bent.
I just wanted to make sure there wasn't any hidden treasures like 4 pinion rear diff with 24 spline axles before I recycle the thing. I'm pretty sure I'll keep the diff, as it should make a good core if I ever decide to get lockers.
Old June 15th, 2013, 11:46 AM
if you are dtiching the stuff, keep the drive flanges, hubs and stub axles. and the front CVs might be the big AEU2522s which are nice to have. And you need those stubs, hubs, and flanges to use them.
can you post some pics of your old front axle? I might be interested in some of the parts off it.
thx
d
Old June 15th, 2013, 11:56 AM
jafir's Avatar
jafir
Jafir Elkurd
I haven't swapped the front yet, but I'll certainly post photos.
Could I just put the diff, axles, hubs, CVs, drive flanges, etc in the current hosing? I kind of like the idea of the less complicated non-abs swivel setup better than the new disco stuff. I thought I heard I couldn't do that though.
Old June 15th, 2013, 02:05 PM
yup.
you can keep your axle housing, swivels, and knuckles. I had to swap a few studs over from the disco housing to the old one in order to fit the later diff. that was pretty easy to do though.
Old June 15th, 2013, 02:36 PM
jafir's Avatar
jafir
Jafir Elkurd
Originally Posted by Ren Ching View Post
yup.
Well I guess I didn't need that radius arm I just bought.
Pittman arm removal? dameek Defender Technical Discussions 20 October 12th, 2009 07:17 AM
Front Suspension Buckon37s Misc. Chit-Chat 17 November 27th, 2006 01:02 AM
For Sale: Mantec Steering Guard, NSO Rear Shock Mount, Hinged Radius Arm Doogs For Sale - Parts 8 January 26th, 2005 11:28 AM
blown front end & sucky wheel locks jabber Defender Technical Discussions 6 October 25th, 2004 07:35 PM
