Front calipers for vented rotors - Defender Source
Old March 30th, 2012, 08:25 PM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
Does anyone have Defender front calipers for the vented type rotors?
1955 Series I
1975 FC101 Vampire
1994 Defender 90 #916
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old March 30th, 2012, 08:38 PM
budzny
Real4X4
NAS 97 ST/NAS 93 110/62
Birthday Committee Team
I might have it but not sure as I have few new calipers that I don't know the applications. Pictures of what you need will help. Anyway, will bring it this Sunday.
Sal
Old March 30th, 2012, 09:13 PM
ini88's Avatar
ini88
Daniel Marcello
ill send ya some photos. they are a bit wider than the rears. I need them for the Disco because it brakes like shit! Want to upgrade the whole set of rotors and pads so why not go vented upfront
1955 Series I
1975 FC101 Vampire
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old March 30th, 2012, 10:14 PM
Can't you put a spacer plate in the existing caliper ... I saw this on a 110 caliper rebuild once upon I cant recal when.
Old March 30th, 2012, 11:51 PM
ini88's Avatar
ini88
Daniel Marcello
hmmm, I guess you can? If fluid is still able to flow to the other side of the piston I guess it would work.
1955 Series I
1975 FC101 Vampire
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old March 31st, 2012, 03:47 AM
ipgregory's Avatar
ipgregory
Ian Gregory
'97 D90 ST #1008
Been a while since I last looked but I think a set of rebuilt caliper's where really cheap. Or you can probably get the spacer made for small money if you can't buy it on its own I would have thought. It is just a spacer, you can see it in the pic. Get a caliper rebuild kit if you do it that way as you should replace those seals when you split them. You'll need the longer bolts as well.
Name:	Brake Caliper 1.jpg
Old March 31st, 2012, 08:07 AM
http://www.defendersource.com/faq/Br...iper.html#Vent
A lead!
Old March 31st, 2012, 07:09 PM
1962siia88's Avatar
1962siia88
Daniel Rogers
1962siia88
You can use the vented rotors and the caliper spacer from a rrc with vented rotors. The spacer will fit between the disco calipers. You'll need the longer caliper bolts from the rrc too. I'm doing this on my series build too. Havent gotten there yet but have all the parts assemble to do so. Find a rrc in the junkyard, pull the calipers cause you'll need other stuff too like the pins for the pads. Hope this helps.
Daniel
Rovers North Front Headlight Guards $180 Wolf Fabrication For Sale - Parts 2 November 2nd, 2011 08:41 PM
Will Calipers and rotors from a 10 spline D90 work on a Disco Axle tomaco1 Defender Technical Discussions 13 December 14th, 2010 11:16 PM
pair of 90 front calipers Uncle Douglas Wanted 2 August 21st, 2008 09:45 AM
Front Brake Calipers 1of40 Defender Technical Discussions 7 December 30th, 2003 12:46 PM
