Front bump stop mounts for 3 inch stops - Defender Source
Old October 20th, 2014, 07:03 PM
CDeWan
Clay DeWan
5.3L beastie
Anyway - need a set of front bump stops - just the steel so I can drill in a center hole and affix 3 inch bump stops as the fronts have offsetting eyelet mounts on the stock bump stops OR if anyone knows of a vendor them please pass along.
Thanks!
Old October 20th, 2014, 08:01 PM
Ash's Avatar
Ash
Ash Heller
OM606 110 Frankenstein
Do you know the length of the stock bumps? Shooting from the hip I'd guess 2-2.5". I have a set of spacers if you're interested in a bolt-on solution.
-Ash
Geared Restoration Co.
352-572-3236
Old October 21st, 2014, 06:22 AM
CDeWan
Clay DeWan
5.3L beastie
Ash,
There are 5 inch stops with 1 center bolt. The are currently mounted to a set of brackets from the rears - meaning the P.O. took a torch burned out the stock rears and then must used the steel mount, drilled a center whole for the new bumpstops and vwalaa (or however you spell that) and in business. So I need to find a set of the fronts that have already had the rubber burned off. Thank you though.
Clay
Old October 21st, 2014, 07:43 AM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
You don't burn them off, you get under them with a steel paint scraper and pop them off. I might have an un-rubbered pair in my scrap pile if D90 and D1 are the same.
Old October 21st, 2014, 08:23 AM
CDeWan
Clay DeWan
5.3L beastie
o!
hmm, might have to try that as I don't need the stock ones any more thank you.
Clay
mount, top
RTE Shock Mounts, 8" Fox Shocks, Extended Bump Stops SMac Wanted 2 February 24th, 2013 07:39 PM
Front Dislocation Cones and Bump Stop Spacers CDeWan Wanted 2 September 10th, 2012 02:24 AM
Need Spare Carrier Bump Stops/Brackets Shake Wanted 3 February 17th, 2007 08:35 PM
High Quality extended bump stops Roadsiderob Defender Technical Discussions 3 August 28th, 2006 03:19 PM
Bump stops UpnOver Defender Technical Discussions 4 May 7th, 2005 11:55 AM
