Fromt axle half shafts.. - Defender Source
Old June 6th, 2014, 08:16 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Have a set of CVs bit need a set of 24 spline in er shafts. Anyone have a set?
Legend in My Own Mind.
Old June 6th, 2014, 08:40 PM
I think I have 23 and 10 inners but that probably won't help.
Old June 6th, 2014, 08:41 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
I can check pretty sure I have a couple sets
Old June 6th, 2014, 08:44 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Yeah I have 10 spline sets but no 24 splines. Are the cvs all the same or different?
Old June 6th, 2014, 08:48 PM
One Ten's Avatar
One Ten
Sam
1994 NAS SW
I have a set (left and right). $100 shipped.
Old June 6th, 2014, 09:11 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
I have a complete front axle if your interested with 24 splines, and a pallet heading to NJ next week.
Old June 7th, 2014, 01:42 AM
One Ten's Avatar
One Ten
Sam
1994 NAS SW
The set I'm offering are 32 spline at the cv end and 24 at the diff end.
Old June 7th, 2014, 08:18 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Ok. Need to first figure out my parts. I have a set of CVs that are 213mm long with 32 spline inners The problem I now see is that the CV does not fit fully into the stub axle. Is there a guide to stub axles as well.
Old June 7th, 2014, 12:10 PM
One Ten's Avatar
One Ten
Sam
1994 NAS SW
If you're upgrading from the old Range Rover classic style 10 spline stuff it's easier just to unbolt the swivel balls and everything attached to them from a disco axle (assuming you've already installed a 24 spline 3rd member).
I've been down that road.
Old June 7th, 2014, 12:54 PM
Originally Posted by One Ten View Post
If you're upgrading from the old Range Rover classic style 10 spline stuff it's easier just to unbolt the swivel balls and everything attached to them from a disco axle (assuming you've already installed a 24 spline 3rd member). I've been down that road.
Early swivels have a different bolt pattern. Have to watch out for that. Easiest path in my view is just to swap the whole axle assembly.
Old June 7th, 2014, 01:48 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
The axle housing and 3rd are defender. The swivels I believe were disco 1 with abs I'm not sure if the stub axles are wrong or if there are different ones or what
Old June 7th, 2014, 01:58 PM
True. The older swivels have 6 bolts to attach them to the axel housing. All of the NAS ('87 RRC and newer) have 7 bolt swivels. -Jeff
I thought d110 NAS are 6 bolt? I should check.
Old June 7th, 2014, 02:01 PM
One Ten's Avatar
One Ten
Sam
1994 NAS SW
Ok. All in favor of swapping the whole front axle say "aye!" All opposed say "nay!" Lol
Old June 8th, 2014, 09:58 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Ok. I got the stub axles to work. The inner seal was screwed up and not letting the cv to seat.
Rear half Shafts / F&R Drive shafts ( stock ) Rugbier For Sale - Parts 2 September 24th, 2011 09:56 AM
ARB 3rd member, Great Basin Half shafts rear ron For Sale - Parts 17 June 4th, 2010 08:47 AM
HD CV's and Half shafts muskyman For Sale - Parts 3 November 28th, 2006 03:32 PM
half shafts jimmy salmon Defender Technical Discussions 2 August 12th, 2005 12:04 PM
Stock diff, stock rear axle half shafts..... nilesj For Sale - Parts 5 October 15th, 2004 11:10 AM
