Fog or Aux Light Switch/Plug & Switch Plate - Defender Source
Old February 22nd, 2016, 01:10 PM
DPdotCOM's Avatar
DPdotCOM
Dan Pollock
1983 Defender 3 Door
Hey folks, installing some fog lights and would love to use an LR switch. So I got two/three items:
First: would love a fog switch like this or this, IDEALLY with the plug for it so i can just splice it into my Hella wiring harness, that's even better. Otherwise, I'll probably just grab it from here.
And second, looking for a switch plate like this, but again, would rather not wait 3 weeks for it. My third switch spot on the lower panel was enlarged at some point so the normal switch sizes don't work and thus the plate. Bonus points if someone just has the lower dash panel for a LHD truck rather than a switch plate.
Double bonus points if one of the NoVa bros has em and I can pick them up!
Seafoam Green 1983 110 3 Door - sometimes SW, current ST.
Spent it's working years in France, it's mid-life crisis in The Hamptons, and now its golden years in Washington, D.C.
Old February 22nd, 2016, 01:14 PM
First: would love a fog switch like this or this but don't want to pay $70 or wait 3 weeks respectively.
Second, if someone has one of those switches WITH the plug for it so i can just splice it into my Hella wiring harness, that's even better.
And third, looking for a switch plate like this, but again, would rather not wait 3 weeks for it.
Bonus points if one of the NoVa bros has em and I can pick them up!
Dan:
I've got a genuine/factory Aux switch Genuine Land Rover Switch #C38637L, brand new in the box. Should work for your application...$20 and it's yours (I paid something ridiculous like $40 for it). This fits exactly into the "cutout" that's under the dash binnacle.
ID:	143125   Click image for larger version
Old February 22nd, 2016, 01:16 PM
DPdotCOM's Avatar
DPdotCOM
Dan Pollock
God i love this place. 4 friggin minutes. Yes, I'll take it! I'll PM you.
Old February 22nd, 2016, 01:17 PM
For the switch plate, I've got one similar...BUT the rub is it's setup for a conversion over to Carling switches (from the factory switch size).
This is for a RHD vehicle, correct? If I recall from Happy Hour yours was RHD? If not, I've got a smaller LHD one that's custom and will fit with a couple of modifications to the dash area.
All that said, I'd suggest a switch over to Carlings anyhow:
ID:	143128   Click image for larger version
ID:	143130   Click image for larger version
Old February 22nd, 2016, 01:21 PM
DPdotCOM's Avatar
DPdotCOM
Dan Pollock
I think for now I want to stick with the standard switches. All I've got down there are the dash lights, hazard, and now fogs (which are gonna be fused and on a relay). For future knowledge though, to convert the others to Carling or any other switch with a blade style connector, can i just snip the harness plug things and add my own individual connectors to each wire?
LHD version (same applies...requires a Carling conversion...easy to do):
ID:	143135   Click image for larger version
ID:	143137   Click image for larger version
Old February 22nd, 2016, 01:23 PM
I think for now I want to stick with the standard switches. All I've got down there are the dash lights, hazard, and now fogs (which are gonna be fused and on a relay). For future knowledge though, do convert the others to Carling or any other switch with a blade style connector, can i just snip the harness plug things and add my own individual connectors to each wire?
Once you get to the point where you get sick of the factory hazard switch acting up I'm sure we'll be talking .
You can just snip the harness if you want, and crimp on a female spade connector (or whatever connector your require). I actually did the conversion on both my RHD and LHD trucks and left the factory harness "intact" and just ran little jumper wires from the factory harness to the Carling switches.
Old February 22nd, 2016, 01:24 PM
DPdotCOM's Avatar
DPdotCOM
Dan Pollock
I'm sure you're right! For now, the standard switch should do. I PMed you about it.
Old February 22nd, 2016, 01:36 PM
Done deal, shot you a note back....we can link up anytime. Had you mentioned this before Happy Hour last week I could have brought it with .
ht, switch
LED fog lamps work lights fog lights Ben01 For Sale - Parts 2 April 20th, 2015 10:42 AM
Fog Light Wiring to d110 dome switch tebby Defender Technical Discussions 16 April 4th, 2014 01:17 PM
New in box, PRC3432 Rover fog light switch - For Sale HeloBubba For Sale - Parts 4 January 12th, 2013 01:45 PM
Aux. light switch (RRC headlight switch) $40 shipped evilfij For Sale - Parts 0 September 5th, 2008 05:12 PM
License Plate LED Lamp & Rear Fog Lamp Install LenB Smaller Projects 24 December 16th, 2007 08:54 PM
