Engine locking pins for 300 Tdi timing belt - Defender Source
Old September 6th, 2012, 12:12 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
I know I can get it in eBay UK but prefer a US vendor who has it in stock
- Charles Eames
Old September 6th, 2012, 12:30 PM
I just timed my 2.8 and need to get the same set. I had to use drill bits, but would like something more proper.
Julien, can you confirm what the 300 tdi flywheel locking pin thread size is? I really want to compare to the 2.8, since it's in a completely different location, so not sure if the 300 tdi tool is the same. I know the injection pump pin is the same however (9mm)
Old September 6th, 2012, 01:24 PM
Naplm00
Matthew
200tdi is 9mm and the flywheel tool is the same as well
Old September 6th, 2012, 02:58 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Let me check diameter and thread type of wading plug.
- Charles Eames
300 tdi, engine, tdi
Snapped timing belt on Tdi JFD Defender Technical Discussions 53 October 19th, 2012 10:36 PM
300 tdi engine cover on a 200 tdi? jayz Defender Technical Discussions 3 July 28th, 2011 05:27 AM
300 TDI timing belt tensioner sundogcwolfe Defender Technical Discussions 7 December 15th, 2009 12:20 AM
300 tdi engine and 5 speed gearbox k4rovers For Sale - Parts 0 September 19th, 2008 10:55 AM
