Electronic Fuel Injection Control Unit - Defender Source
Old August 28th, 2013, 02:09 PM
tomdavey_III's Avatar
tomdavey_III
Thomas Davey
1994/Defender 90
Anyone have a ERR4943 (14CUX) ECU/ECM for sale. I'm needing to pick one up for my 1994 Defender 90 (NAS) 3.9 liter.
Old August 28th, 2013, 02:20 PM
http://www.landroverpartscheap.com/O...E/ERR4943.html
These seem to have a new price around $4500!!
just find one from a D1 or a RR classic from a breakers
Old August 28th, 2013, 08:15 PM
CDeWan
Clay DeWan
5.3L beastie
hint if you get one out of a RRC you won't have the 85mph fuel cut . Try RoverDude - John Gadd as he usually has a few extras around.
Old August 28th, 2013, 09:37 PM
Yeah because you regularly want to hit 85 plus is a defender.
Old August 28th, 2013, 10:00 PM
Wuss.
Old August 28th, 2013, 11:42 PM
CDeWan
Clay DeWan
5.3L beastie
Talking Wussx2
Originally Posted by evilfij View Post
Wuss.
My thoughts exactly. They still handle well at 85+ even without swaybars. It's not that you have to but someday you may need to when the zombies come.
Old August 29th, 2013, 12:05 AM
Hell Yeah! Down hill, down wind with a tail wind!!!!!
Old August 29th, 2013, 11:01 AM
tomdavey_III
Thomas Davey
1994/Defender 90
Does transmission option matter when searching for an ECU out of a D1 or RRC?
Old August 29th, 2013, 11:25 AM
No, they all work fine in my experience. The one thing you will run into is the outer case does not have tabs to mount to the bulkhead on a 93/94 if you get it out of a disco or RRC but you can swap your old case over.
Old August 29th, 2013, 12:31 PM
CDeWan
Clay DeWan
5.3L beastie
2x
If you have air conditioning it will sit in place pretty nicely above the air conditioning housing on the pass. side. I was able to drill the mounting tab to at least get one nut on.
The more important point I was trying to make in getting an ECU out of RRC or D1 is that you are not limited to solely searching for a 14CUX out of a Defender as you have the option to pick it out of a larger population of vehicles.
And yes down hill with a tail wind with your mirrors tucked in and a bean burrito to provide you a nice nitrous shot should get you over the 85 mph hump.
No they will do 85 on a straight away no problem with the 3.9. It is nice to know you have the ability to pass a slow moving truck. Uphill is another story
Old August 29th, 2013, 03:00 PM
tomdavey_III
Thomas Davey
1994/Defender 90
One last question I hope, and thank you for all the help... Does the "AMR####" number matter on the 14CUX ECU that I am looking for?
Old August 29th, 2013, 03:04 PM
Not in any material sense.
4.2 and 3.9 both work fine. A cold start prom would be better I suppose, but who really cares.
Old August 29th, 2013, 03:47 PM
CDeWan
Clay DeWan
5.3L beastie
Brains
Ron,
Do not all 14CUX come with a cold start prom? and not would you happen to know the different part numbers that do carry it - I may make you resort to the vault of microfische stashed in the basement
Clay
Old August 29th, 2013, 03:56 PM
Ron,
Clay
There have been so many updated PROMs I could not tell you and i dont have a list. (Maybe part of operation pride but i am not sure where those docs are). The last PROMs were the same for 4.2 and 3.9 (believe it or not) Although those were sold years after. Usually there will be a sticker on the outside of the ECU showing it was updated with cold start (my 94 had one). I have never had an issue on 14CUX with cold start and I have probably run a dozen different ECUs over the years. Only on GEMS have I had an issue.
Old August 29th, 2013, 05:32 PM
I've posted the 14cux PDF loads of times. The various tunes are listed in the back.
Old August 29th, 2013, 07:53 PM
I have a 14cux for a 3.9 in the bottom drawer of one of my tool chests. If there's interest I'll dig it out and post the part no. Just been keeping it as a trouble shooting spare but that need hasn't materialized.
Old August 29th, 2013, 08:02 PM
pendy's Avatar
pendy
jim pendleton
89'd90
I have many of them for sale. And I am local to you.
Do you run the Ty's diner ?
legend in my own mind
Old August 29th, 2013, 09:05 PM
rover26c's Avatar
rover26c
Lee
1994 D90 ST
Sorry no clue. What is the stock ECU for a 1994 Defender 90 (NAS) 3.9 liter? So replacing it with a 14cux will improve your driving up to 85 mph?
Old August 29th, 2013, 09:43 PM
attached document lists all the 14CUX tunes - it also has diagnostics .... for those that don't believe in witchcraft and voodoo as valid troubleshooting techniques.
the 85mph is a speed limiter that prevents a defender going over 85mph funnily enough.
Old August 29th, 2013, 10:40 PM
Speed limiter is 89 I thought.
fuel
Calling all diesel guys - Biodiesel??? cbass Defender Technical Discussions 47 January 31st, 2006 11:18 AM
wtb abs control unit chirider Wanted 0 June 15th, 2005 01:19 AM
