Electronic Fuel Injection Control Unit - Page 2 - Defender Source
Old August 29th, 2013, 11:09 PM
I rarely go over 70 ...
Old August 30th, 2013, 09:13 AM
tomdavey_III's Avatar
tomdavey_III
Thomas Davey
1994/Defender 90
Nope, I do not run Ty's Diner. That is great if you could part with one and especially great that you are local. You don't perhaps have a diagnostics tool to read live data do you?
Old August 30th, 2013, 09:15 AM
search rover gauge
Old August 30th, 2013, 09:19 AM
tomdavey_III
Thomas Davey
1994/Defender 90
search rover gauge
Will do
Old August 30th, 2013, 12:44 PM
pendy's Avatar
pendy
jim pendleton
89'd90
I have the rovacom setup and am not willing to loan it out.
The rover guage is a good option for you. And will be more mobile then my equiptment.
If you want to borrow an ECU, maybe a 4.2 version even I can do that for you. Have you cleaned the flame trap on the valve cover yet? Do you have an idea on the fuel pressure?
Anyway I will PM you a phone number.
legend in my own mind
Old August 30th, 2013, 01:40 PM
CDeWan
Clay DeWan
5.3L beastie
70+
If you go 70 you may get run over out here by some other CA. Nutbag. Not advocating exceeding of or admitting to speeds in excess of 85. . But point I believe your trying to make is tall, non aerodynamic vehicle why risk driving at excess speed in something not made for such things.
Old August 30th, 2013, 02:05 PM
tomdavey_III
Thomas Davey
1994/Defender 90
I have not cleaned the flame trap and will have to ask which valve cover has the flame trap? Fuel pressure is 30-32psi.
Old August 30th, 2013, 02:18 PM
Passenger side. Grey canister size of a small Campbell's soup can.
Old August 30th, 2013, 02:30 PM
contents taste about the same too ...
Old August 30th, 2013, 02:50 PM
from my personal collection of special links ... i give you this ...
http://www.conehead.org/Projects/Lan..._injection.pdf
manual test procedures for 14cux components ...
Old August 30th, 2013, 03:20 PM
tomdavey_III
Thomas Davey
1994/Defender 90
very nice, great information! Thanks
Old August 30th, 2013, 04:35 PM
BTW the ECU is the least likely culprit. They take a lot of abuse and either work or don't in my experience. But like the others say they are readily available from Discovery 1s and RRCs which both had 14CUX systems.
I'm here for the D's
Old August 30th, 2013, 05:46 PM
100% agree with Charles ... i
Old August 30th, 2013, 09:17 PM
tomdavey_III
Thomas Davey
1994/Defender 90
Agreed, just ruleing it out
Old August 30th, 2013, 09:28 PM
tomdavey_III
Thomas Davey
1994/Defender 90
What's the best way to clean the flame trap? Carb cleaner?
Old August 30th, 2013, 10:40 PM
Probably a pile of dollars to buy a new one ... Carb cleaner or a regular degreaser would probably work.
Old August 30th, 2013, 11:48 PM
Take the crap out of the inside, soak it in gasoline and clean it off, dry it out, refit.
Old September 1st, 2013, 11:02 AM
That hasn't been the case for me lately. I rarely even see any 14CUX trucks anymore, but I've replaced a handful of fuel injection ECU's in past months.
fuel
Calling all diesel guys - Biodiesel??? cbass Defender Technical Discussions 47 January 31st, 2006 11:18 AM
wtb abs control unit chirider Wanted 0 June 15th, 2005 01:19 AM
