electric fan setup for 300tdi - Defender Source
Old January 13th, 2013, 05:34 PM
isleofbones's Avatar
isleofbones
Mike Deery
1984 D-90
I have a 1984 row d-90 with a 200tdi motor and a 300tdi radiator and intercooler. Looking for a electric fan setup for the fan and intercooler that will fit the 300tdi radiator and intercooler. I have to work around the intercooler hoses and the other obstacles on a 300tdi radiator / intercooler setup.
Old January 13th, 2013, 05:59 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
I fitted a 15" virgo 12v fan to a disco 200tdi shroud, not sure if the 300tdi shroud is the same, but anyways I used some battery box rubber mounts that have the bolts molded in the rubber between the outer ring of the fixed mounting of the fan and the shroud.
I think you could get a 16" unit to fit but it will be a trial and error fit. most fan manufactures have the measurements online.
I intend fitting the sensor to a drilling in the water pump, but you could fit this to the top of the therostat housing, also running a on/off/auto switch in the cab.
Hope this helps
*note to self* I have to get another 200tdi shroud to replace the one I stole for the disco conversation
ID:	64431   Click image for larger version
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old January 13th, 2013, 08:01 PM
isleofbones
Mike Deery
1984 D-90
200 tdi fan shroud
John-
That's an excellent idea. I don't know why I didn't think of it. I think I can do the same thing with my 300 tdi shroud. By the way John, I have a 200tdi defender shroud (2 piece). If you want it, I can let you have it for what I paid. It was $100 plus shipping. Its already back in the box as it didn't fit my application.
Old January 13th, 2013, 09:05 PM
NPT90's Avatar
NPT90
JT
D90 óriginalé
That is brilliant! Hadn't event considered this (forsee the same problem)
Old January 14th, 2013, 07:59 PM
isleofbones
Mike Deery
1984 D-90
John-
Sorry in advance for the elementary question... But, is the fan a push fan or a pull fan. In other words, does it push air into the radiator or does it pull air through it from the outside?
Old January 14th, 2013, 09:36 PM
roverman2010
1985 LR 90 200Tdi
Puller, as per pm to you
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
Old January 14th, 2013, 10:08 PM
The Dro
Dro
1988 Ninety
Originally Posted by isleofbones View Post
John-
This will depend. If the fan goes on the front of the rad it's a pusher and a puller if it's mounted in the back.
The later one is what you are looking for.
I've used Flex-a-Lite on my last 2 rigs and IMO they are great.
FAL has a vast selection of types and models for each unique application.
Check them out.
Old January 21st, 2013, 10:59 PM
Axel's Avatar
Axel
jack
1987 Defender 110 5-door
I used a twin fan that I got for free from a local body shop because its shroud was cracked & the Toyota was an insurance claim. Those types of fans are usually just laying around in body shops, or out back to be thrown away. It's a puller, mounted on the back of the radiator. Then get the nice two-stage x-fan thermostat from x-engineering. The only problem is when you add AC.
300tdi, electric fan, fan, tdi
Electric Cooling Fan 97 info needed. WHITE RHINO Defender Technical Discussions 8 January 8th, 2012 02:11 PM
I'm making a custom fiberglass electric fan shroud for D90, anyone interesed? jaherring Defender Technical Discussions 1 November 22nd, 2005 01:06 PM
Twin Electric fan kit for V8 D90 kiphartzell Wanted 2 March 17th, 2005 01:06 PM
Did 1995 SW D90s come with an electric fan? arbik Defender Technical Discussions 8 March 1st, 2005 01:27 AM
Electric Cooling Fan Brackets wea Wanted 0 December 8th, 2004 12:52 PM
