ECU from '96 or earlier Discovery - Defender Source
Old January 27th, 2015, 05:45 PM
110fender
devin
1987 110
Need it for a D90 with a 4.6l motor in it. Current one is from a P38 that isn't correct. Please let me know if you can help. I'm at 804-241-0745 or PM me. Thanks.
Old January 27th, 2015, 06:20 PM
Mtanzania
Frank
1994 D1 300tdi - Sold :-(
I've got one from a 4.2 Range Rover.
94 D1 300tdi - Sold
93 LWB-Isuzu diesel 5 speed
Old January 27th, 2015, 06:46 PM
jafir's Avatar
jafir
Jafir Elkurd
96 is gems, earlier is Lucas.
Old January 27th, 2015, 07:43 PM
psykokid
Jake
1997 Disco
I've got a couple of spare GEMS ecus. If you know the part number for the one you need I can check and see if one of the ones I have is the same part number. I know that one that i have is for an AEL truck but i believe the other is for a non AEL.
Old January 27th, 2015, 07:50 PM
We need to know from OP if its its a Lucas (95 and prior) or Gems 96 onwards spec 4.6
Old January 27th, 2015, 08:03 PM
the rover shop
shayne young
Since he says that his current one is a p38 and that's not correct I'm guessing I
It's a gems unit..gems ecu would never fit a 14cux system... So I'm guessing he needs a pre evap gems ecu..even with a disco one he is still going to need to go into the programming and turn off security and change some other settings..
psykokid
Jake
1997 Disco
Well, if the ECU that he currently has in there is from a P38 then it wouldn't be Lucas unless there is some rare 14CUX variant of the P38..
Old January 27th, 2015, 08:39 PM
110fender
devin
1987 110
I'll get the specifics tomorrow but I was told I need the 'earlier' model. I've been told by others that the p38 can be reprogrammed to work properly. As it stands, the current one turns off the check engine light and the error messages aren't displayed, the emissions are all screwed up and it wouldn't pass inspection. I'll have more info tomorrow. Thanks for the posts. This is an area I'm obviously not familiar with and appreciate the help so I don't get my head taken off.
------ Follow up post added January 27th, 2015 08:40 PM ------
And yes the shop said I need a 'pre-evap' model....
cover, disco, discovery, ecu
New Front Left Outer Wing Skin (200tdi and earlier) Wilboro For Sale - Parts 1 June 11th, 2014 04:01 PM
Earlier defender value Francois Misc. Chit-Chat 10 September 6th, 2012 08:22 PM
94 D90 AC fan (the earlier system fan on the thing in front of the rad) evilfij For Sale - Parts 5 October 9th, 2011 02:32 PM
Need an ECU... looking for the ECU out of a 95 Disco or equivalent IPSC_GUY Wanted 7 February 16th, 2010 04:36 PM
14CUX O2 sensor (93-95 defender, 95 and earlier disco or range rover classic) evilfij Wanted 0 July 26th, 2009 09:22 PM
