Early style 200tdi oil filter housing - Defender Source
Old July 2nd, 2016, 10:58 AM
east high's Avatar
east high
Gerad Davis
1967/s2a 88 200Tdi
I'm in a bit of a pickle. I had a custom radiator built to work with a 200tdi in my s2a. The situation is that the oil cooler connectors on the rad are early type and the oil filter housing on the engine is the later type that uses o-rings.
Unfortunately my local hose shop needs to see the oil ring side of the hose in order to build a new one. I figure it would be easier to find the old style housing so I can have a hose build with similar connections on both ends.
I'm also interested in a pair of early type oil cooler hoses if anyone has an old pair.
Old July 2nd, 2016, 12:16 PM
Ignotus
gene
1960 109, w/200TDI
Gerad,
I might have some do you have a part number or picture of what you need?
Gene
1960 109
1960 88 Ignotus
Blog;
Old July 6th, 2016, 10:35 AM
east high's Avatar
east high
Gerad Davis
1967/s2a 88 200Tdi
Originally Posted by Ignotus View Post
Gerad,
I found these on an old ebay.au auction. The difficulty in this search is knowing if the connectors are the early beveled type, or the later flat o-ring type. Unfortunately, no one takes pictures of the connection ports. Same with the lines.
Old July 6th, 2016, 10:51 AM
speedpin's Avatar
speedpin
1985 130 Gen IV
olive fitting on left, newer o-ring on right
~ Semper Fidelis ~
Old July 6th, 2016, 12:52 PM
east high's Avatar
east high
Gerad Davis
1967/s2a 88 200Tdi
The olive fitting style is what I need. Housing and old hoses would be extra awesome to find.
Old July 6th, 2016, 01:22 PM
Ignotus
gene
1960 109, w/200TDI
Gerad,
This is what I have. If you see something you need make me a reasonable offer. plus shipping.
ID:	153183   Click image for larger version
ID:	153185   Click image for larger version
Gene
1960 109
1960 88 Ignotus
Blog;
Old July 6th, 2016, 02:11 PM
east high's Avatar
east high
Gerad Davis
1967/s2a 88 200Tdi
I think that's it. As long as the hoses fit snugly into that housing I should be good to go. I'll PM you to sort out the details.
200tdi, tdi
2.5 Td - Oil Filter and Fuel Filter gonzanc Defender Technical Discussions 5 November 3rd, 2012 01:38 PM
300Tdi Oil Filter Housing and Hose triple9music Wanted 8 July 19th, 2012 09:23 AM
200tdi Air filter housing bossman429 Wanted 5 May 18th, 2012 09:40 AM
2.5 Oil Filter Housing gchinsr For Sale - Parts 3 April 5th, 2012 12:02 AM
'94 d-90 Oil filter housing TravelerBT Wanted 13 December 9th, 2008 05:51 PM
» Defender Registry
Meh-Teh
thewap
#304
TRS
Add your Defender
