Early Defender LH door latch - Defender Source
Old December 31st, 2014, 04:50 PM
toad's Avatar
toad
Cutter
I need to replace the latch mechanism for my '86 110 LH drivers door, exterior lift handle with remote pull inside. Currently I have to roll down my window to open the door and even that is getting iffy. If you have a working unit let me know, see attached pictures for reference. I'd like to swap out the key cylinder so I can keep my current matching set. If anyone has a source for new ones I'd consider it also.
Old January 2nd, 2015, 03:28 PM
toad's Avatar
toad
Cutter
Fingers crossed bump.
Old January 3rd, 2015, 12:14 PM
toad's Avatar
toad
Cutter
P No. MUC6980 or MUC2291
Old February 27th, 2015, 09:13 AM
toad's Avatar
toad
Cutter
Bumping this, still need a latch. Getting tired of rolling down the window to open the door.
Old February 27th, 2015, 11:48 AM
what's wrong with yours?
Old February 27th, 2015, 03:37 PM
toad's Avatar
toad
Cutter
Inner latch will not release door. There is no spring tension on outer handle. I've pulled the latch assembly out and fussed with things to no avail. I would drill open the casing to see if I could replace the spring but then I'd be out of any way to latch with questionable results.
Old February 27th, 2015, 03:50 PM
Sounds like you've been through it all, but on my '84 the inner latch won't do anything if the lock button is down. And sometimes the lock button just "falls" down on its own.
Old February 27th, 2015, 03:54 PM
anfonee1's Avatar
anfonee1
Jeffrey
1984 D90 RHD SW
I have some extra from when I built my truck if I can find it I'll be in touch this evening
Old February 28th, 2015, 09:16 AM
toad's Avatar
toad
Cutter
Jeff thanks, let me know if you find one.
Yeah the lock doesn't seem to make a difference unfortunately.
Old March 13th, 2015, 10:13 AM
toad's Avatar
toad
Cutter
Bump. At this rate I'm going to need a new roll down mechanism as well given the wear I'm putting on my window opening the door. If anyone has experience rebuilding these latches let me know, it may be my only option but I'm doubtful it is doable.
Old August 13th, 2015, 10:58 PM
toad's Avatar
toad
Cutter
bump it up
Old December 3rd, 2015, 05:03 PM
toad's Avatar
toad
Cutter
I'm still rolling down my window to get out, anyone have one of these?
Old December 14th, 2015, 08:18 PM
toad's Avatar
toad
Cutter
Looking for a Santa to find one of these for me!
Old December 14th, 2015, 08:33 PM
the rover shop
shayne young
Is this what you need..?? Believe part number is MUC2291..
Old December 14th, 2015, 08:37 PM
toad's Avatar
toad
Cutter
Yeah, I think so, the roll up window/lift up latch mechanism on trucks from 85-87 (not sure on exact years). Need a LH one. Are you an angel sent from baby Jesus?
Old December 14th, 2015, 08:41 PM
the rover shop
shayne young
Here's the right hand one...ya might wanna grab it....
Look at this on eBay:
http://pages.ebay.com/link/?nav=item...obalID=EBAY-GB
LAND ROVER DEFENDER DOORLOCK ASSEMBLY R/H PART NO MUC1032
------ Follow up post added December 14th, 2015 08:42 PM ------
Ummmm, that's NOT what I isually get called on here....but hey, I'll take it..lol..
Old December 14th, 2015, 08:49 PM
toad's Avatar
toad
Cutter
Is that the same? I've got a spare right hand actually, which I'm hesitantly considering drilling apart to transplant the spring out of into my drivers latch. Mainly I don't want to screw myself by ruining one good and one somewhat functioning latch and be left with a piece of string holding my door closed. Maybe I'll pick this up, thanks!
Old December 14th, 2015, 08:52 PM
the rover shop
shayne young
And here's the left hand one....
Land Rover Defender 90/110 Early 1 Piece Door Lift Up Handle LH
------ Follow up post added December 14th, 2015 08:54 PM ------
Yes... I guess I am an angel sent from baby Jesus....
Old December 14th, 2015, 09:20 PM
Bravo. I think this rivals my (daily) driving my series with a dead starter for about 3 months before finally getting around to replacing the starter
Originally Posted by pendy
I'm here for the D's
Old December 14th, 2015, 09:25 PM
toad's Avatar
toad
Cutter
I did this for a week or two in my old 109, honestly it was great watching people's expression and the comments when I cranked started it, they assumed it had to be started like that.
------ Follow up post added December 14th, 2015 09:27 PM ------
Thanks, I'll buy it, the striker doesn't look the same but I'll give it a shot! If anyone has one more like the picture in the OP I'm still interested.
defender, door, door latch
early 110 bonnet latch Rufus Wanted 5 February 7th, 2014 09:02 AM
Defender rear door lock latch assembly FQJ500340 Ben01 For Sale - Parts 5 July 5th, 2013 01:55 PM
Door Latch/Top Adjustments AggieD90 Defender Technical Discussions 6 November 19th, 2008 03:55 PM
SW rear door latch mechanism roverboy For Sale - Parts 8 March 22nd, 2007 02:42 PM
Door Latch Removal outfield Defender Technical Discussions 4 July 24th, 2006 11:49 PM
