dual controls - Defender Source
Old April 3rd, 2013, 10:46 AM
Ignotus
gene
1960 109, w/200TDI
dual controls
Hi,
I am looking for dual throttle controls for a diesel Defender. I need the bracket by the injector pump both cables and adjusters. If you have the part numbers that would help too!
gene
Old April 3rd, 2013, 11:12 AM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
Hand Throttle
Originally Posted by Ignotus View Post
Hi,
gene
Just done this,
ntc7097 throttle bracket, fits on the rear of fuel pump bracket
ntc8011 throttle lever assy, fits on the fuel Pp with the foot pedal cable
ntc8560 bushing, for use with above
nrc 8560 cable secondary
All these parts are form brit-car.com
But there is a kit from John Craddock LTD, rtc6382. This fits on the bulkhead lower panel just out of reach, so no cruise control use. This kit is fitted to FFR rovers
Not sure what you mean by both cables?
also you do not mention if you got tdi,turbo or na
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old April 3rd, 2013, 11:35 AM
Ignotus
gene
1960 109, w/200TDI
Thanks Roverman for the quick reply. I have a 2.5Dt (19J) motor. In my repair manual it shows 2 cables attaching to the linkage on the injector pump for dual control--foot/hand. I tried a salvage yard in the UK you might try for a pedal; http://www.cws4x4.co.uk/ they say the dual control is rare. You say you've just done this can you clear it up for me there is NOT 2 cables? a 2 into 1? Pics? Here's what I have;
gene
Sorry I thought it was Roverman looking for the pedal.....then I read the thread. g
ID:	69511   Click image for larger version
Old April 3rd, 2013, 11:58 AM
roverman2010
1985 LR 90 200Tdi
not sure about this, I did it to a 200tdi, I am thinking the kit from John Craddock might be the one you need as it says not for tdi
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
Piaa 90 Xt Pro Dual Lamp System bruinlad For Sale - Parts 2 March 21st, 2005 08:36 PM
Why Dual shock set up? sflash868 Defender Technical Discussions 11 February 28th, 2005 02:34 AM
Dual Batts and HO Alternator jamesriding Defender Technical Discussions 42 January 9th, 2005 04:27 PM
Dual Exhaust Zimbo76 Defender Technical Discussions 16 May 18th, 2004 10:36 PM
