Drive flange, swivel housing? hub? - Defender Source
Old June 4th, 2012, 09:42 AM
OK Trying to piece together the "Ron good" 110 front axle I got from him. It is incomplete on the right side. The swivel ball is there, and the CV. Am I correct that a RRC swivel housing with the fat upper pin hole will work? I think it will, just not 100% sure. I also need a single line caliper for non vented rotors, and a hub. I have a non ABS hub, but the drive flange is the RRC kind so I am afraid that the drive shaft will stick out quite a bit. I suppose one could shim that and circlip it and that would do the trick. There would be some weirdness tho with one side being different.
Heavy Duty Drive Flange Shearpin Defender Technical Discussions 3 May 22nd, 2012 03:41 PM
Tom Wood Custom Drive Shaft: My story. :) Roving Beetle Misc. Chit-Chat 5 April 21st, 2012 01:37 PM
swivel pin housing - grease or oil or both? cgalpin Defender Technical Discussions 27 March 9th, 2007 09:16 AM
Interesting swivel ball problem dameek Defender Technical Discussions 1 July 24th, 2005 01:18 AM
» Defender Registry
D
drsmiley
Rangie
pl626
Add your Defender
