door check strap - Defender Source
Old March 4th, 2015, 01:40 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
door check strap
Need a older model door check strap arm for a right hand front door
The included picture is of the L/H one, its the same rod type not the flat bar kind
MUC1888
I have the bar type but it kills the door seal with it rubbing on it.
thanks
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old March 5th, 2015, 03:30 PM
roverman2010
1985 LR 90 200Tdi
bump
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
Old March 10th, 2015, 10:55 AM
roverman2010
1985 LR 90 200Tdi
Bump
Also needing a set of grey sun visors
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
Old March 10th, 2015, 11:19 AM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
I can still get them new if you're interested, John
Old March 10th, 2015, 01:31 PM
roverman2010
1985 LR 90 200Tdi
Not at $55. Somebody must have one, I'll swap two small quick fist's for one
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
Old March 10th, 2015, 01:43 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
This is cheaper! MUC1888 - Door Check Rod R.H. 90 - 110 up to 1988 Rod Type
Old March 16th, 2015, 10:36 AM
roverman2010
1985 LR 90 200Tdi
door checkstrap, trim & vent
Bump, also looking for a set of the front door galvanized outer door trims for early 90&110
And need a 200tdi wing vent, no need for fancy, I just want to add a vent cover as I will no be getting the raised air take fitted before scarr.
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
Old March 17th, 2015, 10:51 PM
roverman2010
1985 LR 90 200Tdi
Bump,
check strap rod MUC1888
also looking for a set of the front door galvanized outer waist capping for roll window doors, early 90&110
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
door
WTB: MWC6450 Door Check Strap Part BlackField Wanted 2 December 15th, 2013 05:51 AM
boge check strap bjf Wanted 8 April 15th, 2010 12:28 AM
D-90 Door check or check rod question dfscott Defender Technical Discussions 6 November 29th, 2005 11:51 AM
Picture of Door Check Strap mgrgpg Defender Technical Discussions 6 October 24th, 2005 08:39 AM
Wanted - SW Door Check Strap/Bar mgrgpg Wanted 0 September 28th, 2005 08:32 AM
