Dislocation cones - Defender Source
Old April 26th, 2014, 10:47 PM
Squaretyre's Avatar
Squaretyre
Landan
94 d90
Dislocation cones
Both rear spring kicked out today, looking for suggestions on best type of cones to keep them in.
Old April 26th, 2014, 11:02 PM
Ray_G's Avatar
Ray_G
Ray Gerber
Retain vice cones. Less noise/drama.
Otherwise, I think equipe's are nice, RTE...eventually TF if need be.
Old April 26th, 2014, 11:23 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
I'm going to retain after much debate. I have some leftover 2" wide 1/4" plate if you want to pay shipping I'll give it to you. I'll cut to length but you'll have to drill them
Old April 26th, 2014, 11:56 PM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
RTE cones fail EVERY time with long enough shocks. Inverse(bottom mounted) short cones will be your best bet.
Old April 27th, 2014, 02:58 PM
Squaretyre's Avatar
Squaretyre
Landan
94 d90
I'm assuming retain vice cones are a brand. Appreciate any leads as to where to find out more on them. I've seen RN and TF, just want to compare before choosing.
Appreciate offer on steel, looking for off the shelf at this point.
Old April 27th, 2014, 03:03 PM
retain versus cones means the spring is retained top and bottom and stretches like a slinky as opposed to dropping out of the upper spring cup. It's not a brand, instead its a totally different design/concept.
Old April 27th, 2014, 03:17 PM
Squaretyre's Avatar
Squaretyre
Landan
94 d90
Gotcha, so tops are secured similar to bottoms. Quite a bit of weight with axle and all, heck of a retainer clip.
Old April 27th, 2014, 03:21 PM
Given how lame the stock lower retainers are- not really. As Zack offered a piece of 2x1/4 bar stock and some grade 8 bolts will do it for cheap.
Old April 27th, 2014, 04:20 PM
350rangerover
3
I personally like the bars that bolt the springs in place, when the axle is articulated that much to where the spring falls out their is no weight on that wheel rendering it useless.
just my 2 cents
Old April 27th, 2014, 05:06 PM
Squaretyre's Avatar
Squaretyre
Landan
94 d90
I wasn't putting the iron offer together with retaining clips to hold in place. Got it now, have plenty of iron and will go that route.
Old April 27th, 2014, 05:14 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Years ago RTE(and others) made the cones on top.
Now, the cones are typically made for the bottom(on the axle).
I would do neither; retain.
EE used to sell the real nice spring retainers; I cant find them on their site anymore.
Rent my
Old April 27th, 2014, 05:15 PM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
I'm still blinded by those mugs. What did you just say? ;-)
Old April 27th, 2014, 05:46 PM
+1 for retaining.
Old April 27th, 2014, 06:30 PM
myoverlandrover's Avatar
myoverlandrover
josh
109
X springs?
Defender 110
Old April 27th, 2014, 06:38 PM
Arcadeus's Avatar
Arcadeus
Mark Bichin
97 NAS Station Wagon LE
X20 on the retain... Limits articulation a bit but makes up for it by limiting the "holy shit its going to roll" factor.
Old April 27th, 2014, 07:10 PM
I retain at the bottom, and have some custom "cones" that come down from the top perch. Seems to work for me, under definitely the most extreme circumstances.
Old April 28th, 2014, 03:13 PM
Squaretyre's Avatar
Squaretyre
Landan
94 d90
Put 4" 1/4 plate on top with 2" 1/4 strap below then grade 8. See how they work. Didn't see need to secure top plate by welding it on. As always, open for thoughts if should be different.
Old April 28th, 2014, 03:23 PM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
Looks good to me!
Old April 28th, 2014, 03:37 PM
well done
Old June 4th, 2014, 05:12 PM
IIRC Billy's rig has inverted short dislocation cones on the bottom and the springs are only retained on the top. Seemed to have worked well for him
spring retainers vs dislocation cones wantone Defender Technical Discussions 10 March 21st, 2012 02:28 PM
QT Services Reverse Dislocation Cones A2040 - NEW JohnC For Sale - Parts 6 October 24th, 2011 02:03 PM
WTB dislocation cones, 7.5 X16 (or 235/85) tires, brass plug iamgoode Wanted 3 January 21st, 2011 05:03 PM
Rear Dislocation Cones TDI Guy Misc. Chit-Chat 3 October 11th, 2009 08:50 PM
School me on dislocation cones ... Retrofit Defender Technical Discussions 13 January 26th, 2008 02:35 PM
