defender to P38/d2 bolt pattern adapters/spacers - Defender Source
Old September 11th, 2015, 12:13 PM
Want to run Mondials on a defender. Thought I'd see if anyone had some lying around or a source ?
Old September 11th, 2015, 12:15 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
I have a guy in Florida that makes them. I'll send you his info
Old September 11th, 2015, 12:18 PM
rovertrader's Avatar
rovertrader
Dale
Might would sell mine:
Old September 11th, 2015, 12:52 PM
D90Overkill's Avatar
D90Overkill
David Frank
1995 ST #2615
Why did I always just assume they would fit? Face:Palm! I really wanted to know what it would look like! Thanks for posting the pic! Like a more rugged Kahn! ;-)
Old September 11th, 2015, 12:57 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Well, Kahn did copy the design. So that would make sense!
Old September 11th, 2015, 02:12 PM
The cool thing about building myself a 110 completely from a pile of acquired parts is that it can go in any direction. Recent parts trades have it looking like its coming together as a 5 door, ribbed roof, push button door, gems v8,auto. I'm leaning towards stornoway, bonatti, or similar color all over.
Galvanized frame,bulkhead, t posts, tub supports etc. Black leather,td5 dash, w d2 rear seat conversion, black carpet.
Probably only take me a couple years since I'm booked up building other peoples trucks.
ID:	129536   Click image for larger version
Name:	bonatti grey 110.jpg
Old September 11th, 2015, 02:41 PM
rovertrader
Dale
Doug, I may take Lara Croft to Uwharrie, and it is Bonnatti minus the flake, so semi flat if you will, or closer to semi-gloss/matt if that helps you decide on color/finish.
Old September 11th, 2015, 02:44 PM
D90Overkill
David Frank
1995 ST #2615
Exactly! But 18" is about as big a rim as one could fit legit AT it MT tyres on. 20" Kahn's are for mall crawlers.
------ Follow up post added September 11th, 2015 11:47 AM ------
Dale, what size tyre is that on your mondial? When I zoom in far enough to see, its a Monet!
Old September 11th, 2015, 03:04 PM
rovertrader
Dale
I had the tires on an F-150, and what I liked for the Rover application is it almost gets tall/skinny look as they are 285/75-18, or 35/11-11.50. Enough sidewall at 8.5" with improved handling IMHO. And can still air down albeit a bit quicker.
Old September 11th, 2015, 09:05 PM
I have had a bonatti grey truck.
Thinking slightly lighter, possibley orkney
Old September 11th, 2015, 09:08 PM
rovertrader
Dale
Nice!
Old September 11th, 2015, 09:36 PM
corris grey
Name:	corris grey110.jpg
Old September 12th, 2015, 07:31 AM
D110DC's Avatar
D110DC
Pete
66 SIIA, 70 IIA, 97 D90
Doug, I still love Stornoway gray painted on my Double Cab build. Shouldn't of ever sold that truck...
Pete
1966 ECR Series IIA
1970 Series IIA (Stella)
1997 D90 ST
2011 LR4 HSE
2010 Range Rover Supercharged
Sadly gone (some more sadly than others):
1983 D110 Double Cab 300 TDi
1989 RRC
1996 D1
2006 LR3
2008 RR
Old September 12th, 2015, 09:46 AM
I love bonatti and corris grey
Old September 12th, 2015, 10:05 AM
rovertrader
Dale
I like the Orkney- may be what I do to the 90, as it has a gray Tickford top, two tone actually- dark top with lighter sides...
ac, defender
Wheel bolt pattern adapters crown14 Wanted 2 August 7th, 2014 08:13 AM
wheels with 4x100 bolt pattern sflash868 Wanted 3 June 3rd, 2010 09:33 PM
Wheel Bolt Pattern NashvilleRover Defender Technical Discussions 3 October 12th, 2007 11:07 PM
LR3 bolt pattern and wheel studs trailerman Defender Technical Discussions 0 May 27th, 2006 10:32 AM
Bolt Pattern Joe P Defender Technical Discussions 3 December 29th, 2004 11:06 PM
