Defender parking brake lever - Defender Source
Old April 16th, 2010, 06:07 PM
bcourtney's Avatar
bcourtney
Robert Courtney
1973 Series III 200TDI
Need a parking brake lever, don't see one on the usual sources.
Old April 17th, 2010, 12:05 PM
CDeWan
Clay DeWan
5.3L beastie
George at RDS has them.
Old April 18th, 2010, 10:08 AM
there are two different levers, the ones on the RDS site are for the later setups where the cable goes directly into the backing plate of the handbrake. There is another version for the ones where the cable goes into a bracket on the side of the transfer box. Then there are different versions for LHD and RHD. I have a spare RHD later style (like the RDs version but I suspect his are LHD) handle if anyone needs that.
rgrds
Dave
Old April 22nd, 2010, 09:09 PM
bcourtney's Avatar
bcourtney
Robert Courtney
This is the brake lever I got from George and this is my brake line, any thoughts on this? The thimble on the lever is too small for the end of the line, I am thinking just cut the thimble off.
ID:	26958   Click image for larger version
Old April 22nd, 2010, 09:46 PM
That lever is intended for the later cable that has a rubber end that fits into that thimble. Other end of the cable goes directly into the drum.
I seem to recall my original early 90 handbrake cable had a threaded end that want into a bracket mounted behind the seatbox. The handle itself itself did not attach in any way to the cable housing, only the inner cable.
which handbrake do you have? bracket on the transfer box or cable directly into the drum?
part number for the cable in your photo?
brake
Parking Brake Abrooks Defender Technical Discussions 15 September 23rd, 2011 09:57 PM
Defender parking brake upgrade question Overlander Defender Technical Discussions 5 August 6th, 2009 10:36 AM
Parking brake retrofit advice Abrooks Defender Technical Discussions 5 April 13th, 2009 11:39 PM
parking brake switch Campbell Defender Technical Discussions 6 September 20th, 2005 08:45 PM
Parking brake light howellm70 Defender Technical Discussions 4 September 27th, 2004 02:19 PM
