Dead D90 Fuel Pump - Defender Source
Old November 4th, 2008, 01:40 AM
Baldewin's Avatar
Baldewin
Chris Baldewin
Bastard 90
Dead D90 Fuel Pump
I'm looking for a NAS 90 fuel pump. The pump itself doesn't need to work and it would be great if the sender worked. I'm installing a second tank (NAS type) and need it for fuel pick up and to determine fuel quantity. I have what I believe to be a range rover type but it doesn't have a vent connection which I think is on the pump unit since there isn't one on the tank.
Old November 4th, 2008, 01:51 PM
rayfi's Avatar
rayfi
Derek Moeller
110
One on ebay right now.
Old November 4th, 2008, 07:44 PM
Baldewin's Avatar
Baldewin
Chris Baldewin
Bastard 90
Derek,
Thanks for the tip as that is what I'm looking for, but I'm a little concerned with the crack in that one.
Old December 3rd, 2008, 01:30 PM
Baldewin's Avatar
Baldewin
Chris Baldewin
Bastard 90
Found one!
Old December 3rd, 2008, 01:46 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
I have an extra fuel gauge if you want a matching one for your second tank.
Old December 3rd, 2008, 08:49 PM
CDeWan
Clay DeWan
5.3L beastie
Chris,
I am also putting in a second tank underneath the passengers seat. I can get you the part number for the factory tank that goes under the pass seat if you need it. It is a pickup tube and sender unit together. I installed the 2nd fuel tank guage on my iron goat dash. Another way to set up keeping track of the gas level in both tanks is installing a toggle that hooks up to each ground wire from the sending unit. That way you can use one guage in the dash and toggle between tanks for a fuel reading. Just a thought.
Clay
Old December 3rd, 2008, 11:44 PM
Baldewin's Avatar
Baldewin
Chris Baldewin
Bastard 90
Andrew thanks for the offer but at the moment I'm not sure what I'm going to do. I don't have a spot to put a second gauge right now and am still trying to get all the bits together to add the second tank.
Originally Posted by CDeWan
Chris,
Clay
Clay thanks but I'm doing just the opposite of you, I have a ROW truck that came stock with the underseat tank and I am adding a NAS tank in the rear. I acquired a NAS fuel pump and removed the pump section and will be extending the pick up tube so it will mimic a typical diesel sending unit setup.
90, d90, fuel
