D110 seat belts - Defender Source
Old January 8th, 2010, 09:07 AM
disco dog's Avatar
disco dog
Tracy Dwyer
2002 D110 TD5
D110 seat belts
I need a set of rear ( second row ) seat belts for my D110. Need complete set including shoulder straps ect. Anyone have these?
PURA VIDA !!
Old January 10th, 2010, 10:40 AM
disco dog's Avatar
disco dog
Tracy Dwyer
2002 D110 TD5
Come on now, someone must have a set of these. (02 -110)
PURA VIDA !!
Old January 10th, 2010, 03:16 PM
Best4x4's Avatar
Best4x4
Kelly Graham
P38
I think you can Range Rover classic front belts...you would need a couple of the rear y belt latches to bolt to the floor.....This is a way cheaper way to go. I do have a set of new floor latches for the front seats....if you need that style...Good luck
Old January 10th, 2010, 06:53 PM
The later model 110's seat belt reels go behind the rear roof side trims. Gustavo is about to put the new style stuff in his truck and will be removing the second row shoulder belts currently in his truck.
Old March 2nd, 2010, 11:05 AM
disco dog's Avatar
disco dog
Tracy Dwyer
2002 D110 TD5
Still need these, anyone have ?? Gustavo??
PURA VIDA !!
Old June 24th, 2012, 01:52 PM
Abrooks's Avatar
Abrooks
Tony Brooks
Anyone found a way it install inertia 3 point belts into an early 110?
Old June 24th, 2012, 05:20 PM
usadventureracing's Avatar
usadventureracing
Brett
110
I have a set but they have red paint on them and are pretty dirty
1983 ROW D110
1970 Series III (Parting out)
Old June 24th, 2012, 07:58 PM
Abrooks's Avatar
Abrooks
Tony Brooks
Do you have the mounting brackets for the C pillar as well?
Old June 25th, 2012, 06:14 AM
usadventureracing
Brett
110
I am using the brackets.
1983 ROW D110
Old June 25th, 2012, 08:40 PM
the rover shop
shayne young
so do you need the ones that go in the middle or lower section (base of) of the c-pillar..???
Old June 25th, 2012, 08:43 PM
Abrooks's Avatar
Abrooks
Tony Brooks
I think I'm going to need both (don't have the truck yet). It's got lap belts but that's it. I've tracked down some part numbers but have conveniently left them at work . . .
what've you got?
Old June 25th, 2012, 09:55 PM
the rover shop
shayne young
Like someone said..the earlier ones had the seat belt cassette (inertia reel) mounted to the floor at the base of the c pillar and both ends of the seat belt were on that bracket..and the later ones..(I guess from about 85 on) had the cassette mounted half way up the c pillar and the other end mounted down at the base of the c pillar....these were right about shoulder height and had a trim piece that covered it.. the centre had a lap sash belt that always fell down between the seats..I think I have new and used on either sort...
Old June 25th, 2012, 10:09 PM
the rover shop
shayne young
heres a pick of the later ones mounting point..
http://we-r-rovers.smugmug.com/Other...amel-007-L.jpg
lower section of the pic about midway across.. notice the trim piece that covers it...this is part of the whole rear sliding window trim piece and is completely different to the earlier ones..
Old June 26th, 2012, 10:05 AM
Abrooks's Avatar
Abrooks
Tony Brooks
Interesting! Do you know if either early or late versions can be retrofitted easily to one that only has lap belts?
Old June 26th, 2012, 11:05 AM
LRover's Avatar
LRover
J. Michael McCaig
I used the rear seat belts out of a '95 Disco for the rear of my '85 110SW and they worked great with no modifications. Everything bolted up with the stock hardware in the stock locations (The inertia wheel for mine is just in front of the rear side window).
Old June 26th, 2012, 12:19 PM
Abrooks's Avatar
Abrooks
Tony Brooks
Were the mounts hiring behing the trim on your truck Mike?
Old June 26th, 2012, 12:52 PM
usadventureracing
Brett
110
Can you show pictures as I have new seatbelt from RN and I am having a problem installing them.
1983 ROW D110
110, d110
Set of Seat Belts rvrnut110 Wanted 0 February 3rd, 2006 01:52 AM
female short seat belts for jump seats Marc Weinstein Wanted 0 March 24th, 2005 08:54 PM
BFG MT 265/75, winch bumper and rear seat belts jvelador Wanted 0 September 26th, 2004 02:50 AM
Side Brackets for Rear Bench Seat & Rear Seat Belts zed111 Wanted 2 August 16th, 2004 12:33 PM
Side Brackets for Rear Bench Seat & Rear Seat Belts zed111 Defender Technical Discussions 2 August 13th, 2004 05:33 PM
