CV joint - Defender Source
Old September 11th, 2015, 11:48 AM
bossman429's Avatar
bossman429
Adrian
1988 90
CV joint
Need (1) CV joint
Or i'll take the whole assembly, Short side, 24spline. For a D1 assembly but should be same as Defender.
Old September 11th, 2015, 11:53 AM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
We have new ones decently cheap
Old September 11th, 2015, 12:18 PM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
If you wait a bit you can have mine after I put my HD shafts in.
1955 Series I
1975 FC101 Vampire
1994 Defender 90 #916
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old September 11th, 2015, 12:26 PM
rovertrader's Avatar
rovertrader
Dale
'94 and '95 don't have tone rings, but shouldn't be an issue on an '88 if you have already switched to Disco.
Old September 11th, 2015, 12:31 PM
bossman429's Avatar
bossman429
Adrian
1988 90
Not an 88 ( sold that truck guess i should update my profile).
Its a 95 disco axle assembly going into a coil sprung 2a.
------ Follow up post added September 11th, 2015 12:31 PM ------
Dan rough idea when your doing the swap?
Old September 11th, 2015, 01:52 PM
ini88's Avatar
ini88
Daniel Marcello
Really anytime, I could come down and do them at your place. Really I would love to do then when I put in the front locker which I need to do soon anyways.
1955 Series I
1975 FC101 Vampire
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old September 11th, 2015, 02:42 PM
rovertrader
Dale
I have a couple Disco/NAS Defender sitting on shelf if you need it quickly.
Old September 11th, 2015, 02:48 PM
bossman429's Avatar
bossman429
Adrian
1988 90
Ok I'll send you a text and we'll see what works
Rear Wishbone Ball Joint Assembly, Tie Rod End & Drop Arm Ball Joint Rebuild Kit BMGmotors Defender Technical Discussions 18 June 27th, 2011 01:59 PM
steering drop arm ball joint souza Defender Technical Discussions 20 February 29th, 2008 11:41 AM
a-arm joint/ wishbone joint cbass Defender Technical Discussions 4 January 21st, 2007 09:35 PM
Rear A-arm Ball Joint ronward Defender Technical Discussions 4 February 25th, 2004 08:53 AM
rear ball joint mattdh Defender Technical Discussions 3 October 13th, 2003 04:28 PM
