Cryoteck hinges - Defender Source
Old March 5th, 2015, 11:42 PM
rayfi's Avatar
rayfi
Derek Moeller
110
Cryoteck hinges
AM I even spelling that right?
I am interested in a set for my 110 front and mid doors.
Anybody?
Old March 6th, 2015, 02:52 AM
Arcadeus's Avatar
Arcadeus
Mark Bichin
97 NAS Station Wagon LE
Be ready to shell out some big bucks....
Old March 6th, 2015, 07:39 AM
Croytec
Old March 6th, 2015, 08:15 AM
The latest TD5 spec hinges are pretty damn good ... I've had them in for several years in the north east together with stainless hardware with no deterioration.
The can be sourced as new take off in the UK on the fronts at least for not a lot of money.
Old March 6th, 2015, 08:26 AM
87 D110 (Ruby)
560 quid ... Eeeeek.
Old March 6th, 2015, 11:32 AM
Greenbull's Avatar
Greenbull
Mark Miller
1994 Defender 90NAS #1258
im not much of a speller, but it I think its Croytec.
CroytTec Products -Door Hinges-
-Jeff
I think the Cryotek hinges come FROZEN
Old March 6th, 2015, 11:34 AM
Arcadeus's Avatar
Arcadeus
Mark Bichin
The latest TD5 spec hinges are pretty damn good ... I've had them in for several years in the north east together with stainless hardware with no deterioration. The can be sourced as new take off in the UK on the fronts at least for not a lot of money.
I'm using the new td5 hinges as well... They are a direct replacement unless you have a St where you have to slightly grind one on each side. They differ from the old ones in that they have a bushing in them to prevent water egress. Haven't heard of anyone having rust issues with them yet.
Old November 10th, 2015, 02:29 PM
jason1st
Jason Crandall
2006 LR3 2012 SC 1983 110
Will new/updated hinges make the doors fit better? My doors sag and look like sh%^&
Old November 10th, 2015, 02:34 PM
You can adjust the door alignment by loosening the hinge bolts.
Old November 10th, 2015, 02:46 PM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
Does anyone have a photo of the TD5 hinge ground down to accommodate the ST capping?
Old November 10th, 2015, 02:49 PM
You don't grind the hinge. You grind the capping. Or, at least, you should.
Old November 10th, 2015, 02:53 PM
down_shift's Avatar
down_shift
Russell
I looked into that when test fitting a larger set hinges. It would be 3/16-1/4" off the capping. No thanks. Not interesting in repainting the capping.
Old November 10th, 2015, 03:11 PM
jason1st
Jason Crandall
OK. But I'm assuming the hinges on my 1984 110 are original and they're shot. Will new hinges help or will new require the same amount of alignment? I just got my truck out of the shop and the doors look like shit. The shop says they've done all they can do.
Old November 10th, 2015, 03:16 PM
Are they shot? When you lift on the door, does it wiggle from loose hinges?
All you do is loosen the bolts on the bulkhead and adjust up. That said, most bolts are rusted solid. If you do change hinges, make sure you are prepared to deal with bolts that are seized. I suggest just drilling the heads off all the bulkhead bolts and not even trying to loosen them. Replace with all new stainless hardware and TD5 hinges.
Dare I ask which shop is incapable of adjusting a door?
Group Buy (feeler): stainless steel door hinges, safari door/bonnet/bulkhead hinges nathanwind For Sale - Parts 52 November 30th, 2011 04:58 PM
hinges dmarchand Misc. Chit-Chat 62 December 23rd, 2004 10:02 AM
Door Hinges Krna Misc. Chit-Chat 0 February 10th, 2004 06:52 PM
motosource hinges tonymotosource Misc. Chit-Chat 0 December 9th, 2003 09:50 AM
New non-corrosive alloy door hinges and bolt kit c2sox Misc. Chit-Chat 24 December 8th, 2003 03:16 PM
