crossmember - Defender Source
Old February 22nd, 2013, 01:07 PM
CDeWan
Clay DeWan
5.3L beastie
crossmember
Anyone have a rear crossmember for a 90 or 110 (I think they are the same...or at least they look reallly reallly similar I know that the 130s and new crossmembers are different with that big cut out) lying around that has been cut right where it affixes to the frame rails? so basically just the front of the cross member or side that faces outward. Can be rusty or a bit dented just need to use it as a pattern.
Thank you!
Old February 26th, 2013, 08:39 AM
Rufus's Avatar
Rufus
Rufus
1994 NAS D90 ST #1118
Clay the 110 and 90 rear crossmembers are different
"Sometimes, there's a man. And I'm talkin' about the Dude here. Sometimes, there's a man, well, he's the man for his time and place"
D90 Yahoo Group member since 2001
Old February 26th, 2013, 12:54 PM
CDeWan
Clay DeWan
5.3L beastie
Rufus,
Thank you. Do you happen to know the difference other than how they mount. I am more worried about the difference in the face of the crossmember than the backside of it
Buffer between corner guards & 2" receiver on rear crossmember nathanwind Defender Technical Discussions 3 February 13th, 2013 01:30 AM
Rear crossmember and Bumper kennybahr Defender Technical Discussions 7 July 18th, 2008 10:57 PM
Rear Crossmember Repair mattarm Defender Technical Discussions 2 June 27th, 2006 07:07 AM
D-90 Rear crossmember neo812 Wanted 2 August 1st, 2004 02:29 PM
