Couple items - Defender Source
Old November 12th, 2015, 07:57 AM
bossman429's Avatar
bossman429
Adrian
1988 90
Couple items
Rear Upper Shock Mount Bracket (pair) (will take hardware and bushes if you have as well in good condition)
Shock Tower Retention rings (pair)
Spring isolators (both front and rear.
Anyone have? OEM or aftermarket OK as long as in good condition
edit: all this is for a disco axle set up but should be same as a defender
Old November 12th, 2015, 08:10 AM
I have a pair of 2 inch drop rear upper shock mounts - were on my truck prior to swapping to my Rockware hoops, if you're interested.
Old November 12th, 2015, 08:37 AM
bossman429's Avatar
bossman429
Adrian
1988 90
Ok. Not sure if there are any negatives to running those with a 2" lift...will look into and get back to you.
Old November 12th, 2015, 10:55 AM
They are precisely what you need for a 2" lift, if you're using stock shocks. I'll try to see if i can fit these into a flat rate box.
Old November 12th, 2015, 11:00 AM
Just make sure you install 1" longer bump stops if using 2" lower shock mounts.
Old November 12th, 2015, 11:02 AM
bossman429's Avatar
bossman429
Adrian
1988 90
10-4. My concern would be you would bottom out the shock on compression if it was too low. I guess that's a legit concern!
Ed shoot me a price on those brackets when you can.
Old November 12th, 2015, 11:09 AM
Yes, I've measured everything up with the springs out and with the normal 1" extended bump stops, you can safely use the 2" lower shock mounts. With stock bump stops, you will bottom the shock in articulation.
It is a good setup for people with a lift. The lift springs usually prevent you from hitting the stock bump stops and you lose useable articulation.
Old November 12th, 2015, 11:12 AM
Also, depending on the length of your springs, you may need to do something to prevent the springs unseating. Something to check.
Old November 12th, 2015, 11:26 AM
bossman429's Avatar
bossman429
Adrian
1988 90
Good point. That I won't know until I get it all together. Can always add cones later. Then again I will prob never get this thing that twisted up to find out.
Old November 12th, 2015, 11:52 AM
The Dro
Dro
1988 Ninety
I'll send you the rear bushings (brand new)...
I have several from my TerraFirma kit I didn't use.
Old November 12th, 2015, 11:56 AM
bossman429's Avatar
bossman429
Adrian
1988 90
Rock on - thanks Dro!
Old November 12th, 2015, 11:58 AM
The Dro
Dro
1988 Ninety
Sure thing
A couple of items... Andy R Misc. Chit-Chat 140 December 22nd, 2012 09:09 AM
Couple of Items for sale Shawn For Sale - Parts 2 August 15th, 2011 07:34 PM
I am dropping the fuel tank and I have a couple of questions, help QUEST Defender Technical Discussions 24 September 26th, 2009 03:26 AM
couple of things jblieb Defender Technical Discussions 3 October 5th, 2005 04:36 PM
