County Classic bits needed - Defender Source
Old June 4th, 2015, 07:18 PM
Drivers memory seat switch. The green memory buttons are missing from mine
right rear door pocket
window switch wood panel
wood piece shifter sits into
radio spacer bezel
Old June 4th, 2015, 09:37 PM
I can try but those are all hard to find. Radio bezel is like gold. What color door pull pocket?
Old June 5th, 2015, 10:10 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
I might have the seat switch; when my seat ECU took a dump I just replaced it with a standard switch.
I doubt I tossed it but I'll have to search around.
Rent my
Old June 5th, 2015, 10:29 AM
I'm not married to the memory functions but if you replace the memory switch with a standard one what happens with the mirrors ? Currently the mirrors don't respond. does simply unplugging the memory module and swapping the switch fix the issues ?
Old June 5th, 2015, 11:07 AM
Bill the door pocket is the large pocket @ the bottom of the door card, not the door pull. Lightstone interior color, so its going to be fun to find.
Old June 6th, 2015, 10:54 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
You can pull the ECU and simply plug in the old style switch for seat movement.
That's what I did for the quick fix.
I manually moved the mirrors into a useable position and left them there.
I'll try a bypass fix in the future.
Rent my
Old June 8th, 2015, 07:57 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Found this old beat up switch...
Rent my
Old June 8th, 2015, 08:07 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Under the seat hook ups--Doug, looks like I did splice into the harness where that electrical tape is; dont remember that.
That's the power supply source going into the switch.
Rent my
Abrooks's Avatar
Abrooks
Tony Brooks
Sounds like a good opportunity to do a manual seat swap.
Old June 8th, 2015, 08:17 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
yeah, if you could find manual seats anywhere!
Final pic- connector going to motors(the green and yellow on the left)-- switch on the right
This is what I was talking about on the phone Doug- you can apply 12v+ to those green/yellows and get seat movement.
Then you can pull the bolts and remove the seat- remove the ecu, etc,
Rent my
Old June 8th, 2015, 08:55 PM
Dano G.'s Avatar
Dano G.
Dan Grip
97 d1
I've repaired a few memory modules. If the circuit boards not completely fried you can still get the replacement batteries and make a jumper or two...
Old June 8th, 2015, 09:01 PM
Doug you can't just swap memory for manual. You need a working seat ECU to get the mirrors operational. Either send me yours or I can try to repair one of the ones I have here. The lightstone should have sorrel door cards. I only have one pocket which is going on my door!
Fwiw the SEM palomino vinyl paint is very close to sorrel.
Old June 8th, 2015, 10:35 PM
Jeff,
Thanks for your time today. Hopefully your patient in the chair wasn't annoyed with me picking your brain.
That was a trip when I moved the seat switch and the mirrors responded.....
Instead of going after the seat I tore into the dash since I have no blower motor. The wood duct/facia was already off when I got it so I may as well fix it and then put it back together. Hoping for a switch issue
Old June 9th, 2015, 09:51 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Doug is getting mirror movement when he moves the seat buttons---won't know how bad the board is until he gets a peek inside the ECU.
Yes, you can switch to a plain power seat switch but you'll lose power mirror function.
I just moved my mirrors manually and left them.
There is a remedy for the mirrors but I don't know it.
Rent my
Old June 9th, 2015, 11:07 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
So Mrs Nomar doenst drive it and mess with the mirrors?
-Jeff
She's tall enough they're within working range.... but it's stinky- so she doesnt drive it too often...
Rent my
Old June 9th, 2015, 12:16 PM
Dano G.'s Avatar
Dano G.
Dan Grip
97 d1
http://robisonservice.blogspot.com/2...emory.html?m=1
------ Follow up post added June 9th, 2015 08:19 AM ------
Just found module masters has remained ones...http://modulemaster.com/rebuilds/sho...at-controller/
Old June 9th, 2015, 01:27 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
^^ Nice links, Dan ^^
Robison to the rescue again
That's not a terrible price on a reman ECU...
Rent my
Old June 9th, 2015, 01:59 PM
They want $300 to repair, you don't get a new ECU.
Old June 9th, 2015, 02:32 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Right.
A renewed ecu.
Repair of damaged printed circuit board
Replacement of capacitors nearing end of life
Application of conformal coating to prevent further corrosion
Installation of sealed battery pack with special protective connectors
5-10 business day rebuild time (may be longer if unexpected circumstances arise)
Five-year warranty against return failure
We do not charge a bench test fee
That doesnt sound that bad for 300 clams.
What would you charge for the above?
Rent my
Old June 9th, 2015, 03:25 PM
I got the batteries for $12 each, and the Integrated Circuits were like a couple dollars for 10 of 'em.. I wouldn't charge anything, myself. No real need to change the capacitors unless they are damaged. In some cases the board can be saved if it isn't too bad. I have seen everything from completely useless to almost pristine save for a bad battery. Got a pile of 'em here. One or two are savable with some work.
I also remove the ICs and replace them with a socket. Then plug new ICs into the socket.
Conformal coating is merely clear Krylon.
Anyway those guys are running a business. I can see charging what people will pay but honestly it's maybe a half hour's work to refurbish one, and the parts are peanuts.
classic
Range rover classic bits phunter Misc. Chit-Chat 0 October 24th, 2014 09:58 PM
Range fover classic interior bits mountainviewrover For Sale - Parts 15 October 20th, 2013 01:35 AM
1985 LR 90 county bits mgreenspan For Sale - Parts 3 May 8th, 2012 04:41 PM
my ebay postings roll cage bits, tub supports, D1 GBR drive shaft, Classic Rockslider CDeWan The Flea Market 3 January 19th, 2010 01:46 AM
Breaking 89 County Classic Doug Crowther For Sale - Parts 2 January 26th, 2007 07:49 PM
