Complete Auto Trans Conversion Kit - Defender Source
Old August 13th, 2013, 11:37 AM
themaxx's Avatar
themaxx
Ade
94 ST
Looking for a complete Auto Trans Conversion, including:
NAS Center console
Shifter
Shifter Gater
Cables
Lines
ZF Auto Box
etc...
Old August 13th, 2013, 11:44 AM
The Dro
Dro
1988 Ninety
That's a tall order.
Try Ashcroft Transmissions.
Old August 13th, 2013, 11:48 AM
I would have thought it would be easier and cheaper to buy a 97 rather than retrofit this into a 94
Old August 13th, 2013, 11:52 AM
Reese_D90's Avatar
Reese_D90
Reese
97 D90 ST and 93 D110
I converted my 93 NAS 110 with Ashcroft parts and console to a ZF. Worked great. No complaints. I bought everything but the transmission from them. Bought the transmission locally. All in with local parts about $4k.
NAS 1993 D110 CDN #11/25
1997 D90 ST #1953
2006 Range Rover
1997 D90 SW #701 (sold)
1995 D90 ST (sold)
Old August 13th, 2013, 11:55 AM
RoversNorth
RN
2012 Land Rover Defender
We have the Ashcroft kit in stock, it's very nicely done.
http://landroverparts.roversnorth.co...OMATIC-&key=it
Rovers North
1319 Vt Rt 128, Westford, VT 05494
Please message me with any questions you have.
Old August 13th, 2013, 12:10 PM
Ade are you coming to HH? Talk to me about the manual bits you take out please if you do this conversion.
Originally Posted by pendy
I'm here for the D's
Old August 13th, 2013, 04:08 PM
themaxx's Avatar
themaxx
Ade
94 ST
Will definitely be at HH this week!
My plan isn't to convert my 94 ST. I'm looking to pick up the parts for a future Defender purchase. Still working on convincing my wife though...
------ Follow up post added August 13th, 2013 04:09 PM ------
Ashcroft should have all of it. http://www.ashcroft-transmissions.co...iewCat&catId=7
-Jeff
Thanks Jeff and Dro!
Old August 13th, 2013, 04:54 PM
Broncoduecer's Avatar
Broncoduecer
peter
D90
you can use the stock cooler lines from a 97 and the stock trans cooler. Or you can custom fab some lines and make custom cooler. The fittings to the trans are M16x1.5. So you can use some aeroquip ends and fab up your own solution.
I cut out the air dam and put in some mesh to get air to the cooler. But then I put on a winch and the rockware bumper, so I don't know what kind of flow it gets. When I get the diesel and auto in I plan on having a trans temp gauge, so I will be able to see if that's going to work, or build my own.
Old August 13th, 2013, 05:51 PM
Reese_D90's Avatar
Reese_D90
Reese
I have an extra 97 trans cooler if you need it.
1997 D90 ST #1953
2006 Range Rover
1995 D90 ST (sold)
Old August 13th, 2013, 09:31 PM
themaxx's Avatar
themaxx
Ade
94 ST
Thanks for the info! Did you address the EFI issue?
------ Follow up post added August 13th, 2013 09:31 PM ------
PM sent
Old August 13th, 2013, 09:46 PM
Broncoduecer
peter
D90
No I never did since I planned on swapping to the diesel. There is a resistor that you need to cut from the harness about 6 in from the main connector. Orange and black wire.
There is also the neutral safety switch and "brake to shift out of park" to fix if you desire. I never had either, but plan to put in something for the NSS. The whole press the brake to shift from park sounds like another gremlin to chase down the road.
And the interlock issue is also correct. You want to make sure you're not in gear when try to shift the transfer case. I did not build that feature in either.
Old August 14th, 2013, 12:01 AM
themaxx's Avatar
themaxx
Ade
94 ST
Good info.
conversion, kit
TD5 complete engine kit w/R380 and all parts for conversion $5500 obo ZombieMotors For Sale - Parts 9 May 5th, 2013 07:13 AM
Auto Trans Cooler Lines mhansen Defender Technical Discussions 5 January 30th, 2006 11:51 PM
Need 97 auto trans shifter light unit thingy wicks Wanted 2 December 22nd, 2004 12:59 PM
3rd - Detroit Locker 4.10, Auto Trans, Steering Box, ABS Pump mudrover For Sale - Parts 2 August 9th, 2004 12:25 PM
Auto trans output shaft extension needed JCRover4x4 Wanted 1 June 15th, 2004 10:10 PM
