Comp/Alternator Mounting Hardware - Defender Source
Old July 8th, 2011, 05:14 PM
Smirk1010
Justin
1986 3.5 V8 Ninety
I am adding AC to a 1986 3.5 V8 Ninety and I am looking for the compressor and alternator mounting hardware as well as power steering pump pulley. The main part numbers are listed below. Please let me know if you have any of these parts or know where I can find them. Thanks.
Alternator Brackets:
ERC6538
ERC7548
ERC6547
Compressor Brackets:
ERC7494
ERC6545
Power Steering Pump Pulley:
610792
Old July 9th, 2011, 07:32 AM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
Is that the setup for the York compressor? (don't have time to look that all up now).
if so I think Craddock in UK had most of it last time I looked. http://www.johncraddockltd.co.uk/pro...r_90110_v8.php
I may have all of it also (84 RRC) but will not be back at the shop until Tuesday to confirm .
Matt Browne
Old July 9th, 2011, 04:52 PM
Smirk1010
Justin
1986 3.5 V8 Ninety
Not sure about the compressor manufacturer. But that raises a good question. Will that bracket work with a newer model compressor? The one pictured in the LR parts manual looks significantly different from those in the later models. Would a compressor bracket for a 4.0V8 fit in a 3.5?
Old July 10th, 2011, 07:02 AM
junkyddog11
oil soaked filter
95 RRC 300tdi
The older bracket works only for the York type compressor.
The 4.0 will not work(easily).
One way out is probably the front end from a 3.9 (timing cover out) which will give you all the bits you need for your AC plus a water pump and other ancillary parts that can easily be sourced . Can be had cheaply from a junk yard late model Range Rover. 87 to 91 would be the easiest years to scavenge. I've done this quite a few times.
Matt Browne
alternator, bracket, compressor, mount
Stainless Steel Hardware Kit boshea Defender Technical Discussions 53 September 4th, 2006 01:21 AM
Bushing hardware question D90user Defender Technical Discussions 3 November 30th, 2005 03:54 PM
Rear Bench Seat + hardware Chaucer For Sale - Parts 8 September 29th, 2005 12:16 AM
Rear Bench Seat Hardware sigma Wanted 0 May 10th, 2005 04:53 PM
ARB Bumper Mounting Hardware dnewman9 Defender Technical Discussions 1 February 1st, 2004 04:04 PM
