Clutch Pedal Assembly - Defender Source
Old March 23rd, 2015, 12:39 PM
bjf's Avatar
bjf
barry f
94 ST #395
Anyone have a clutch pedal assembly for a 94 truck. This is the style that has one spring not two.
Old March 23rd, 2015, 02:10 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
New or used?
Old March 23rd, 2015, 02:16 PM
bjf's Avatar
bjf
barry f
94 ST #395
New would be ideal.
Old March 23rd, 2015, 02:48 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
New would be ideal.
SKB500280 New, LR OE - in stocků $80 plus shipping down the coast ($~20?)
Opened the box to snap photo for you
May have a few used ones floating around the parts racks
Old March 23rd, 2015, 02:53 PM
bjf's Avatar
bjf
barry f
94 ST #395
Ah but that is the dual spring. I want the one that has one spring on it.
Granted looking at the pic it is one spring that goes on both sides.
I don't think the style I want is made anymore.
Old March 23rd, 2015, 03:00 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
Coil spring? Like the early type?
Got a couple early type used
Old March 23rd, 2015, 03:05 PM
bjf's Avatar
bjf
barry f
94 ST #395
yeah early type. I have all the parts to rebuild mine but I was wondering if it was possible to just get a new one. Is it possible to replace all those bushings without pulling the pedal box from truck?
Old March 23rd, 2015, 03:19 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
You wants the Td5 style one, got mine from Safari last year
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old March 23rd, 2015, 03:21 PM
The later style is better....
Old March 23rd, 2015, 03:22 PM
$80 for a new one is not worth rebuilding anything.
Old March 23rd, 2015, 03:29 PM
madcowdungbeetle has one in pieces....
Old March 23rd, 2015, 04:09 PM
bjf's Avatar
bjf
barry f
94 ST #395
Couldn't tell if that was the same.
I'm sure the newer one is better. I just wanted to keep it original.
Old March 23rd, 2015, 08:38 PM
wmatos1001's Avatar
wmatos1001
William
1994 NAS Defender 90
Attachment 116755
Related question. Does anyone know how to get access to the panel labeled #13 in the diagram provided? I have some strip caulk that I want to use as I have water coming in during car wash/heavy rain right through the clutch pedal that I believe is leaking at that panel. I trouble shooted that based on a 90/110 LR dealer water ingress guide.
Problem is I can't seem to locate that side of the panel. Do I have to get the bulkhead exposed?
Will
Old March 23rd, 2015, 08:40 PM
The panel is under the hood. Where are you looking?
Old March 23rd, 2015, 08:41 PM
lordhelemt's Avatar
lordhelemt
Paul
1995 D90 #2620 & NAS 110
Originally Posted by wmatos1001 View Post
Related question. Does anyone know how to get access to the panel labeled #13 in the diagram provided? I have some strip caulk that I want to use as I have water coming in during car wash/heavy rain right through the clutch pedal that I believe is leaking at that panel. I trouble shooted that based on a 90/110 LR dealer water ingress guide. Problem is I can't seem to locate that side of the panel. Do I have to get the bulkhead exposed? Thanks, Will
#13 is the access panel to adjust the pedal height. It's under the bonnet on the engine side of the firewall
RIP 1994 D90 #999 (engine fire 2002). We'll miss you.
Old March 23rd, 2015, 08:42 PM
wmatos1001's Avatar
wmatos1001
William
I have been looking on the driver side (it's a NAS 90 LHD) under the hood (from the top of engine looking down) but there seems to be a large box like structure in the way. I don't have pics handy but that's my recollection.
Thanks for the quick reply.
------ Follow up post added March 23rd, 2015 08:44 PM ------
Do either of you have any experience with water getting in from this area? It comes in pretty good if I'm in a spray car wash gets my clutch foot soaked!
Its the only place it comes in except for a little by the driver sliding window but I have replacement felt and a rivet gun to take the door upper apart and fix that.
Old March 23rd, 2015, 08:46 PM
Between the brake booster and the wing.
Water gets in everywhere in a Defender. Lots of places to get in.....
Old March 23rd, 2015, 08:48 PM
Picture with the wing off.
Old March 23rd, 2015, 08:59 PM
wmatos1001's Avatar
wmatos1001
William
Got it awesome thank you (especially for the awesome pic with the wing off) this is extremely helpful.
Old March 23rd, 2015, 11:49 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
If there is a significant amount of water intrusion here - look at the bonnet gasket to see if the runoff is being drained into the clutch pedal box. Pull the inspection cover and replace the gasket. Release the pedal box (all 6 screws) and look for the gasket to be compromised at the upper section. A new gasket and a small amount of sealing material in the "pocket" usually do the trick.
Clutch box assembly, Fuel Pedal assembly tomaco1 Wanted 1 April 29th, 2012 11:36 AM
WTB Clutch pedal assembly for 94 D90 Broncoduecer Wanted 1 February 2nd, 2011 08:30 PM
Brake Pedal Assembly e90miller Wanted 3 July 5th, 2010 07:26 PM
I really need a gas pedal assembly evilfij Wanted 0 September 27th, 2009 05:50 PM
D90 throttle pedal assembly and throttle cables Willard For Sale - Parts 2 October 14th, 2008 10:31 AM
