Clock - Defender Source
Old July 30th, 2014, 08:20 PM
ScottS's Avatar
ScottS
Scott Shelley
Clock
Looking for a working clock for my 94 D90
Old July 30th, 2014, 09:24 PM
Daddymow's Avatar
Daddymow
Raub A.
1987 D110 Tithonus
iPhone works better.
Old July 30th, 2014, 09:53 PM
ScottS's Avatar
ScottS
Scott Shelley
Thanks for the help...
Old July 31st, 2014, 10:26 AM
CDeWan
Clay DeWan
5.3L beastie
Round or square style? PM me as I think I have both.
Old August 1st, 2014, 10:55 AM
CDeWan
Clay DeWan
5.3L beastie
only have round. The square one is toast.
Old August 1st, 2014, 06:08 PM
Reese_D90's Avatar
Reese_D90
Reese
97 D90 ST and 93 D110
I think I have a square one
NAS 1993 D110 CDN #11/25
1997 D90 ST #1953
2006 Range Rover
1997 D90 SW #701 (sold)
1995 D90 ST (sold)
Old August 1st, 2014, 06:25 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
I think I have a square clock ; what are they going for these days?
$50?
Rent my
Old August 1st, 2014, 09:43 PM
ScottS's Avatar
ScottS
Scott Shelley
GaryBaxter offered me one for $30 shipped. I hope to hear back from him. If I don't hear back I'll still be looking.
Old August 1st, 2014, 10:01 PM
Rufus's Avatar
Rufus
Rufus
1994 NAS D90 ST #1118
You can pull one from a RRC at a junk yard
"Sometimes, there's a man. And I'm talkin' about the Dude here. Sometimes, there's a man, well, he's the man for his time and place"
D90 Yahoo Group member since 2001
Old August 2nd, 2014, 12:04 AM
ScottS's Avatar
ScottS
Scott Shelley
Thanks everyone for your help. I just to my clock apart and fixed it. I like when things work out like that.
------ Follow up post added August 1st, 2014 09:06 PM ------
That would be "took"
Old August 2nd, 2014, 09:55 AM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
Interested in what is behind that bezel. What failed and how did you fix it? I've always thought the analog clock is one of the more iconic "Defender" items in the interior. In a rental Chrysler 300 this weekend and the entire dash put an emphasis on the analog clock. Nice that old school is cool again.
Old August 2nd, 2014, 11:04 AM
ScottS's Avatar
ScottS
Scott Shelley
What I found when investigating was that the last owner had disconnected the power. when I connected it I found that the minute hand was being dragged by the second hand and looked a little off center. It would just turn in unison to the second hand. I decided to open it up and take a look. Once the clock is pulled from the truck it is easy to take apart. The two metal tabs that hold the clock in the dash slide outward and there are two small plastic catches that if pushed in with a screw driver will release. The whole mechanism will come out of the case, what I found was a bunch of plastic gears and a small electric motor. There are three shafts that the 3 different hands sit on with a pressure fit. The outer shaft is the hour hand, the middle shaft is the minute and the inner is the second. The second hand shaft is splined and the second hand slide over that and acts to hide/trim out everything. What I found once I removed all the hands was that the outer(hour hand) shaft had move forward after all these years and pushed the minute hand off its shaft. The minute hand was resting against the second hand and was being turned by it. I simply pushed back the hour hand shaft to expose the minute hand shaft, refit all the hands and slid the case back on. I plugged it in and it worked like a charm!
Old August 2nd, 2014, 01:59 PM
down_shift's Avatar
down_shift
Russell
Nice work. Thanks for sharing.
D90 Clock Rejuvinated - One fix arbik Defender Technical Discussions 0 March 2nd, 2005 07:34 PM
WANTED: '97 D90 Clock muskatd Wanted 0 January 26th, 2005 05:33 PM
Clock Light Bulb ronward Defender Technical Discussions 1 April 28th, 2004 04:13 AM
Factory clock problems Art Vigil Defender Technical Discussions 9 February 11th, 2004 11:20 AM
Fuses? Horn and clock... OCD90 Defender Technical Discussions 3 November 17th, 2003 06:05 PM
» Defender Registry
newbie1
marcd
Baloo
phreeb
Add your Defender
