Center Diff Thrust Washers - Defender Source
Old December 19th, 2005, 06:40 PM
Paul Grant
Paul Grant
I am looking for a set of four thrust washers for the center differential in an LT230. The part number for these brass washers is FRC6968 although that number may have been changed. These are the washers that fit between the spyder gears and the diff housing. I've tried all the usual suspects to no avail. If you have a set or know where on this side fo the Atlantic I can find them please let me know.
Paul
paulgrant@mac.com
Old December 19th, 2005, 11:52 PM
Roadsiderob's Avatar
Roadsiderob
Robert Dassler
1994 D90
GBR sells a one piece cross shaft kit that comes with hardened steel thrust washers...very nice but some side gear shimming is usually required to get the clearances correct.
Rob Dassler
SWR Automotive
505-872-7818 (shop)
Old December 21st, 2005, 08:14 AM
Paul Grant
Paul Grant
Rob,
Bill at GBR is sending me the MacNamara hardened steel thrust washers but just in case, I'll take the set you have as well. PayPal has been sent. Better safe than sorry!
Paul
Center Diff Lock Issues (on, off, or in-between) Heath Defender Technical Discussions 10 October 29th, 2017 01:39 AM
center diff lock light bjf Defender Technical Discussions 16 June 25th, 2016 07:06 PM
Center Diff Locked will not Unlock! Hammertime Defender Technical Discussions 2 May 7th, 2009 03:16 AM
HELP!! Center Diff Acting wierd? sorry so long Hammertime Defender Technical Discussions 3 April 25th, 2009 10:32 PM
How to troubleshoot my central different locker? MonLand Defender Technical Discussions 7 July 5th, 2005 10:57 PM
