Center Dash housing - Defender Source
Old June 8th, 2009, 04:38 PM
Bozman's Avatar
Bozman
Greg
1991 200tdi D90
Center Dash housing
Center Dash housing, as pictured.
I don't need the switches, just everything else in the picture. Actually, all I really need is the dark gray bit as I have the outer housing. But I wanted to keep it a little less complicated.
Thanks!
Old June 8th, 2009, 08:51 PM
Not sure if this is the same size, but george has something on this page
http://www.roversdownsouth.com/defender.htm
http://www.roversdownsouth.com/image...witchPlate.JPG
Old June 8th, 2009, 08:58 PM
Bozman's Avatar
Bozman
Greg
1991 200tdi D90
Yeah, I saw that but I am pretty sure that is different than what I need.
Thanks for the heads up tho'
Old June 10th, 2009, 08:24 AM
Bozman's Avatar
Bozman
Greg
1991 200tdi D90
Bumpity bump.
Old June 10th, 2009, 11:35 AM
Shane@EVS
Roverhybrids
I should have that somewhere............I'll have to do some digging
Old June 11th, 2009, 07:06 AM
Bozman's Avatar
Bozman
Greg
1991 200tdi D90
Fingers are crossed.
Old June 11th, 2009, 11:26 AM
Greg I have that part. Bought it from Safari Rover for $70. Never used it. Has the switches but no guarantees on those. Was going to cut it up for VDO gauges and went a different route.
Old June 11th, 2009, 11:47 AM
Bozman's Avatar
Bozman
Greg
1991 200tdi D90
Doug,
I will take it . . . $17 shipped?
Just kidding, I will send you an email.
Greg
Old June 12th, 2009, 12:27 PM
Shane@EVS
Roverhybrids
found the switch panel piece. I just have the dark grey part with the 3 switches. It has had two more holes drilled next to the other switches, looks like they put a couple of toggle switches there
Old June 15th, 2009, 08:17 AM
Bozman's Avatar
Bozman
Greg
1991 200tdi D90
Thanks, but Doug ended up finding the piece I needed. I will let you know if his doesn't work out.
I really appreciate the help.
Greg
dash
MTC4618LOY Center Dash Trim 90/110 FS SafariHP The Vendors Loft 4 October 13th, 2015 08:40 AM
Need a center dash switch holder Uncle Douglas Wanted 3 September 27th, 2012 06:40 PM
Center dash electrical gremlins kellymoe Defender Technical Discussions 6 December 8th, 2009 01:37 AM
Center Dash Fascia for Gauges Hoss Wanted 15 March 3rd, 2006 03:58 AM
Blank Stainless Center Dash Panel (bling) JimC For Sale - Parts 0 November 18th, 2004 03:56 PM
