Bulb holders - Defender Source
Old February 17th, 2014, 12:09 PM
Squaretyre's Avatar
Squaretyre
Landan
94 d90
Bulb holders
Looking for bulb holders on dash that illuminate the fan on one side, temp on other. Called the typical shops but no luck with these priceless gems. Currently mine have more superglue than plastic left.
Appreciate any leads
Old February 17th, 2014, 12:26 PM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
NLA (unless you score some used ones from the back of a RR Classic heater display).
With a drill and a file you can turn the hole where these go into a circle and then file 2 slots in that hole. This will allow you to use the more common bulb holder that won't break each time you remove it. (You'll have to change the terminals on the wires too (to larger ones)).
Email:
Old February 17th, 2014, 12:33 PM
Squaretyre's Avatar
Squaretyre
Landan
94 d90
Oh good thought, thanks. I was able to find the round ones which will make that work.
Warning light panel - bulb holders leastonce Defender Technical Discussions 0 February 18th, 2011 10:53 AM
Electrical Question #1: Difference between Bulb Holders Manimal Defender Technical Discussions 4 August 26th, 2010 12:59 AM
dash light bulb holders ex mod d110 1991 singingcamel Wanted 0 April 27th, 2010 05:02 PM
Side lamp bulb holder Neo Defender Technical Discussions 5 January 30th, 2004 05:07 PM
Best Jerry Can Holders? wicks Misc. Chit-Chat 39 January 4th, 2004 11:13 PM
» Defender Registry
Daisy
lmwong
D90
95beluga
Add your Defender
